TomTom VIA 1605TM Back Cover Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,212
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
GPS may be dropped and the back screen is cracked/damaged. When prying do not use metal tools as this can cause static damage. The device can be identified by its model number which is located under the small panel on the bottom of the device.
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
    1. TomTom VIA 1605TM Back Cover Replacement, Front Screen: step 1, image 1 of 3 TomTom VIA 1605TM Back Cover Replacement, Front Screen: step 1, image 2 of 3 TomTom VIA 1605TM Back Cover Replacement, Front Screen: step 1, image 3 of 3
      • Locate the round suction cup on the back of the device.
      • Twist the suction cup clockwise or counterclockwise while pulling back away from the device closer to your body until removed.
      • When reassembling twist the suction cup but, push in as oppose to pulling out.
      Ask FixBot
    2. TomTom VIA 1605TM Back Cover Replacement: step 2, image 1 of 1
      • Location of screw is where the suction cup was.
      • Insert 8mm Hex #T6 screw driver into screw.
      • Unscrew in counter clockwise direction.
      • When reassembling screw in the clockwise direction.
      Ask FixBot
    3. TomTom VIA 1605TM Back Cover Replacement: step 3, image 1 of 2 TomTom VIA 1605TM Back Cover Replacement: step 3, image 2 of 2
      • Pry along the edges with the plastic opening tool to separate the back and front panel.
      • Try not to tear the screen open as you may break the part. Go about this gently but with enough force to remove the screen.
      Ask FixBot
    4. TomTom VIA 1605TM Back Cover Replacement: step 4, image 1 of 3 TomTom VIA 1605TM Back Cover Replacement: step 4, image 2 of 3 TomTom VIA 1605TM Back Cover Replacement: step 4, image 3 of 3
      • Place the new front panel (with new screen) on to the back panel. Press firmly along the edges to attach.
      • Only do this step of placing the front panel on if you are completed. If there are still components needed replacing postpone this step until the end.
      Ask FixBot
    1. TomTom VIA 1605TM Back Cover Replacement, Motherboard: step 5, image 1 of 3 TomTom VIA 1605TM Back Cover Replacement, Motherboard: step 5, image 2 of 3 TomTom VIA 1605TM Back Cover Replacement, Motherboard: step 5, image 3 of 3
      • Keep the TOMTOM oriented so the curve is on the bottom.
      • Remove the four 1 mm Phillips #1 screws attached to the motherboard.
      • The LCD screen does not disconnect from the motherboard until the next step.
      Ask FixBot
    2. TomTom VIA 1605TM Back Cover Replacement: step 6, image 1 of 3 TomTom VIA 1605TM Back Cover Replacement: step 6, image 2 of 3 TomTom VIA 1605TM Back Cover Replacement: step 6, image 3 of 3
      • Remove the blue ribbon cable by pushing each side of the plastic holder with the nylon spudger.
      • Remove the LCD from the motherboard.
      Ask FixBot
    3. TomTom VIA 1605TM Back Cover Replacement: step 7, image 1 of 1
      • Unplug the wire connecting to the speaker by pinching the sides connected to the back screen.
      • Pull back away (in the opposite direction) from the connector.
      • When reassembling, push back into connector. You do not need to pinch anything. The "click" sound ensures solid connection.
      Ask FixBot
    4. TomTom VIA 1605TM Back Cover Replacement: step 8, image 1 of 2 TomTom VIA 1605TM Back Cover Replacement: step 8, image 2 of 2
      • Unplug the battery, the same way we unplugged the speaker by pinching the sides of the connection.
      • Pull away from the connector.
      • When reassembling push back into connector. Do not need to pinch anything. The "click" sound ensures solid connection
      Ask FixBot
    5. TomTom VIA 1605TM Back Cover Replacement: step 9, image 1 of 1
      • Properly dispose of the old motherboard. Replace with the new motherboard.
      • Skip this step (i.e. do not dispose of motherboard) if this part of prerequisite guide for the back cover replacement.
      Ask FixBot
    1. TomTom VIA 1605TM Back Cover Replacement, Back Cover: step 10, image 1 of 1
      • Replace the back cover screen, now that all parts have been properly removed.
      Ask FixBot
Tyler Wade
362 Reputation
3 Guides authored
UMass Dartmouth, Team 4-4, Catania Fall 2015 Member of UMass Dartmouth, Team 4-4, Catania Fall 2015
UMASSD-CATANIA-F15S4G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,212
