Up to 20% off select tools
TomTom Runner Front Cover Replacement
Views: 7.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
105
All Time:
7,209
Comments: 10
1 comment on steps, 9 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide shows you how to replace the outer casing of the watch. If you have an outer cracked screen, main button, or case, then this is the guide you need.
    1. TomTom Runner Front Cover  Replacement, Wristband: step 1, image 1 of 1
      • First, lift the bottom part of the band to start removing the wristband from the button area of the watch.
      Ask FixBot
    2. TomTom Runner Front Cover  Replacement: step 2, image 1 of 2 TomTom Runner Front Cover  Replacement: step 2, image 2 of 2
      • Continue to lift up on the band until the screen of the watch becomes loose from the band.
      • You may need to apply a small amount of force downward on the face of the screen.
      • Continue to pull up on the wristband until it is completely off the watch.
      Ask FixBot
    1. TomTom Runner Front Cover  Replacement, Back Panel: step 3, image 1 of 1
      • Grab the watch once it is separated from the wristband.
      Ask FixBot
    2. TomTom Runner Front Cover  Replacement: step 4, image 1 of 1
      • Flip over the watch and remove the four 3.0 mm Torx head screws with a T4 Torx head screwdriver.
      Ask FixBot
    3. TomTom Runner Front Cover  Replacement: step 5, image 1 of 2 TomTom Runner Front Cover  Replacement: step 5, image 2 of 2
      • Remove the two 3.0 mm Torx screws from the front. Use a T4 Torx screwdriver to remove the screws.
      • The two 3.0 mm Torx screws are painted blue at the end. These screws have screw holders around them that will also need to be removed.
      • Unscrew the screws from the front of the watch casing and the screw holders fall out from the back of the watch casing.
      Ask FixBot
    4. TomTom Runner Front Cover  Replacement: step 6, image 1 of 2 TomTom Runner Front Cover  Replacement: step 6, image 2 of 2
      • Gently pull the back panel away from the front panel.
      • Do not to pull too fast or too hard. There are red and black wires connected to the vibrator component that should not be ripped.
      Ask FixBot
    5. TomTom Runner Front Cover  Replacement: step 7, image 1 of 2 TomTom Runner Front Cover  Replacement: step 7, image 2 of 2
      • Gently wiggle the black box vibrator component away from the back panel with your fingers or a Spudger tool.
      • Be gentle with the red and black wires. You do not want them to rip or pop out.
      • The vibrator component is the small black box with the silver metal part at end. The black box is glued down, so it will take a little force to free it and it will be sticky.
      Ask FixBot
    1. TomTom Runner Front Cover  Replacement, Front Cover: step 8, image 1 of 2 TomTom Runner Front Cover  Replacement, Front Cover: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Now lift the smaller square of copper off the Front Panel. Use the bent, metal precision tweezers and slide it under the smaller square of copper lining then gently lift it up.
      • You will need to be gentle and pull the copper slowly so that it does not rip.
      Ask FixBot
    2. TomTom Runner Front Cover  Replacement: step 9, image 1 of 2 TomTom Runner Front Cover  Replacement: step 9, image 2 of 2
      • Use the bent, metal precision tweezers to remove the thin copper piece from large square silver piece in the Front Casing.
      Ask FixBot
    3. TomTom Runner Front Cover  Replacement: step 10, image 1 of 1
      • Remove the two 2.0 mm Torx Head screws with the T5 Torx screwdriver.
      Ask FixBot
    4. TomTom Runner Front Cover  Replacement: step 11, image 1 of 3 TomTom Runner Front Cover  Replacement: step 11, image 2 of 3 TomTom Runner Front Cover  Replacement: step 11, image 3 of 3
      • Use your fingers to gently pull the whole green motherboard out of the Front Casing.
      • If you have trouble using your fingers, then use the black Spudger tool.
      Ask FixBot
You are finished when all parts have been removed to leave just the front casing by itself. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Author
with
Amber Scarborough
1,157 Reputation
5 Guides authored
9 Guide Comments
Great explaination, though you mention you don't replacement parts...? Can you share a link where you found the new front cover assembly?
steffen klifman - Reply Share
Same question as Dyeffen : where can we get some replacement screens ?
Ansre
a_limal@yahoo.com.au
Andre - Reply Share
Steffen sorry :-(
Andre - Reply Share
Same question: where can we find the replacement cover part?
Thomas - Reply Share
Hello if the control button is tight can the button be removed and cleaned underneath
Imran
Imran Moosagie - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 105
All Time: 7,209
