Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓Before beginning this guide you should have completed guides on removing the back cover and separating the circuit board from the front cover.
Locate the 4 .4mm screws connecting the circuit board to the front panel.
Use the T6 Torx screwdriver and remove the four screws.
Tool used on this step:Tweezers$4.99
Locate the ribbon cable connecting the front panel to the circuit board.
Locate the white tab locking the ribbon in place.
Using precision tweezers push the left and right side of the tab forward.
Gently pull the ribbon to disconnect the circuit board from the front panel.
