TomTom ONE Motherboard Replacement
    1. TomTom ONE Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
      Ask FixBot
    2. TomTom ONE Motherboard Replacement: step 2, image 1 of 2 TomTom ONE Motherboard Replacement: step 2, image 2 of 2
      • Using the spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
      Ask FixBot
    3. TomTom ONE Motherboard Replacement: step 3, image 1 of 1
      • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
      Ask FixBot
    4. TomTom ONE Motherboard Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover.
      Ask FixBot
    5. TomTom ONE Motherboard Replacement: step 5, image 1 of 1
      • Next, you must remove the motherboard from the front screen.
      • Use a Torx T-7 screwdriver to unscrew the two screws.
      Ask FixBot
    6. TomTom ONE Motherboard Replacement: step 6, image 1 of 2 TomTom ONE Motherboard Replacement: step 6, image 2 of 2
      • Before you can seperate the motherboard from the front cover, you must disconnect the wire connecting the two.
      • To do so, you must use the back end of the spudger to push out the two white tabs connected to the wire, that holds the motherboard and front cover together.
      Ask FixBot
    7. TomTom ONE Motherboard Replacement: step 7, image 1 of 1
      • The motherboard is now disconnected from the front assembly
      Ask FixBot
4 other people completed this guide.
Becca
220 Reputation
2 Guides authored
Cal Poly, Team 7-7, Maness Spring 2010 Member of Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 36
All Time: 10,603
