Up to 20% off select tools
TomTom ONE Back Cover Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
96
All Time:
7,795
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The back cover on the TomTom ONE is likely to chip or break due to excessive use. The mount guides can get worn down and not function properly. This guide will help you to replace it.
    1. TomTom ONE Back Cover Replacement, Back Cover: step 1, image 1 of 1
      • Use a T-9 Torx screwdriver to unscrew the four screws on the back cover.
      Ask FixBot
    2. TomTom ONE Back Cover Replacement: step 2, image 1 of 2 TomTom ONE Back Cover Replacement: step 2, image 2 of 2
      • Using a spudger, gently pry apart the back case from the front case. It is easier to start on a side and work your way around the device.
      Ask FixBot
    3. TomTom ONE Back Cover Replacement: step 3, image 1 of 1
      • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device.
      Ask FixBot
    4. TomTom ONE Back Cover Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Once the two covers are separated, use tweezers, or even your fingers, to gently disconnect the two sets of wires that are connected to the motherboard from the back cover. You may have to wiggle the wires a little bit to get them to disconnect.
      Ask FixBot
    5. TomTom ONE Back Cover Replacement: step 5, image 1 of 1
      • As you can see, the battery and the speaker are still attached to the device and must be removed.
      • Using the spudger, carefully pry out both the battery and the speaker.
      • When taking out the speaker, the entire plastic shock mounting casing will come out.
      • The battery may seem tough to get out due to the adhesive used to secure it. Just slowly work at it and do not force anything.
      Ask FixBot
    6. TomTom ONE Back Cover Replacement: step 6, image 1 of 1
      • Once the battery and the speaker are removed, you now only have the back cover!
      Ask FixBot
2 other people completed this guide.
Author
with
Trevor Foster
148 Reputation
3 Guides authored
Cal Poly, Team 7-7, Maness Spring 2010 Member of Cal Poly, Team 7-7, Maness Spring 2010
CPSU-MANESS-S10S7G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 96
All Time: 7,795
