Introduction
The Tomtom Go Blue&Me is specific to certain models of Fiat, Alfa Romeo, Lancia, Jeep and Chrysler. This model is basically a Tomtom, with a "custom" boot screen showing the brand of the car it is connected to. The pedestal/stand that connects it to the car, is only the power supply. For the data connection, Bluetooth is used.
Use a flat head screwdriver or plastic spatula to remove the bezels from the side of the screen.
Now the torx screws are visible
When the screws are out, the screen is separated from the back of the housing.
the screen is still connected with a flat cable and a power cable
The power cable should be pulled first
The flat cable can be disconnected by lifting up the black part of the connector.
Next, the main board should be disconnected from the battery
and from the loud speaker
When you now lift out the mainboard, you have access to the battery and loudspeaker.
The battery is glued in. you need to heat it up to get it out.
This little piece of plastic was my reason for opening it up. The longer leg was broken. I glued it with superglue and put it back. so far this seams feasible
Please note the broken bits in the holes at the end of the legs: you can not actually take this out without breaking it! so be ware!
