TomTom Go 60 S Motherboard Replacement
  1. TomTom Go 60 S Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Use the iFixit opening tool to pry open the TomTom Go 60 S. Start from a corner and drag the tool around the device.
    Ask FixBot
  2. TomTom Go 60 S Motherboard Replacement: step 2, image 1 of 1
    • Carefully pull the back cover apart from the front cover. Be careful not to pull too hard because there are two sets of wires connecting the device
    Ask FixBot
  3. TomTom Go 60 S Motherboard Replacement: step 3, image 1 of 1
    • Once the two covers are separated, use your fingers, to gently disconnect the wires that are connected to the motherboard from the back cover.
    Ask FixBot
  4. TomTom Go 60 S Motherboard Replacement: step 4, image 1 of 1
    • Next, you must remove the motherboard from the front screen.
    • Use a Phillips #000 screwdriver to unscrew the screws.
    Ask FixBot
  5. TomTom Go 60 S Motherboard Replacement: step 5, image 1 of 2 TomTom Go 60 S Motherboard Replacement: step 5, image 2 of 2
    • Separate the motherboard from the front cover, you must disconnect the wires connecting the two.
    Ask FixBot
  6. TomTom Go 60 S Motherboard Replacement: step 6, image 1 of 1
    • The motherboard is now disconnected from the front assembly
    Ask FixBot
Ambermarie Dawdy
74 Reputation
2 Guides authored
USF Tampa, Team 1-6, Nance Fall 2016 Member of USF Tampa, Team 1-6, Nance Fall 2016
USFT-NANCE-F16S1G6
4 Members
5 Guides authored
1 Guide Comment
What is the purpose of single yellow wire ?
is it ok if it is disconnected ? I fear to have unsoldered it or is it just an alone wire ?
Thanks
ugo ceruti - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 24
All Time: 1,772
