TomTom GO 500 Opening the Device
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. TomTom GO 500 Opening the Device, TomTom GO 500 Opening the Device: step 1, image 1 of 1
      • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
      Ask FixBot
    2. TomTom GO 500 Opening the Device: step 2, image 1 of 2 TomTom GO 500 Opening the Device: step 2, image 2 of 2
      • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
      • There are 14 latches that need to be undone.
      • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
      Ask FixBot
    3. TomTom GO 500 Opening the Device: step 3, image 1 of 1
      • With the screen casing unlatched, locate the right side where the two connectors are.
      Ask FixBot
    4. TomTom GO 500 Opening the Device: step 4, image 1 of 3 TomTom GO 500 Opening the Device: step 4, image 2 of 3 TomTom GO 500 Opening the Device: step 4, image 3 of 3
      • Unlatch the connectors using the plastic opening tool.
      • The orange rectangular connector may have come off in the process of removing the screen casing.
      Ask FixBot
    5. TomTom GO 500 Opening the Device: step 5, image 1 of 2 TomTom GO 500 Opening the Device: step 5, image 2 of 2
      • Separate the screen casing from the motherboard casing.
      Ask FixBot
jkl
531 Reputation
2 Guides authored
UC Davis, Team 2-5, Oliver Fall 2016 Member of UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 392
