TomTom GO 500 Display or Digitizer Replacement
  1. TomTom GO 500 Display or Digitizer Replacement, TomTom GO 500 Opening the Device: step 1, image 1 of 1
    • Unscrew the two 3mm screws at the base of the device using the Torx T5 screwdriver.
    Ask FixBot
  2. TomTom GO 500 Display or Digitizer Replacement: step 2, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement: step 2, image 2 of 2
    • Using the plastic opening tools, insert one opening tool into the gap between the screen casing and the motherboard casing. Then insert the other tool into one of the adjacent sides and slide it around the top.
    • There are 14 latches that need to be undone.
    • The latches break easily during the opening process so we recommend purchasing a new screen casing if they break.
    Ask FixBot
  3. TomTom GO 500 Display or Digitizer Replacement: step 3, image 1 of 1
    • With the screen casing unlatched, locate the right side where the two connectors are.
    Ask FixBot
  4. TomTom GO 500 Display or Digitizer Replacement: step 4, image 1 of 3 TomTom GO 500 Display or Digitizer Replacement: step 4, image 2 of 3 TomTom GO 500 Display or Digitizer Replacement: step 4, image 3 of 3
    • Unlatch the connectors using the plastic opening tool.
    • The orange rectangular connector may have come off in the process of removing the screen casing.
    Ask FixBot
  5. TomTom GO 500 Display or Digitizer Replacement: step 5, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement: step 5, image 2 of 2
    • Separate the screen casing from the motherboard casing.
    Ask FixBot
  6. TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: step 6, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement, Display or Digitizer: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the microphone on the left side of the screen casing using tweezers.
    • Use tweezers with rounded tips to avoid damaging the microphone.
    Ask FixBot
  7. TomTom GO 500 Display or Digitizer Replacement: step 7, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement: step 7, image 2 of 2
    • Lift up the small black tab on the orange connector using a plastic opening tool. This releases the strip connecting the display to the digitizer.
    Ask FixBot
  8. TomTom GO 500 Display or Digitizer Replacement: step 8, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement: step 8, image 2 of 2
    • Slide the connector strip out from the tab.
    Ask FixBot
  9. TomTom GO 500 Display or Digitizer Replacement: step 9, image 1 of 2 TomTom GO 500 Display or Digitizer Replacement: step 9, image 2 of 2
    • Unscrew the eight 2.5mm screws along the perimeter of the display using the Phillips #000 screwdriver.
    Ask FixBot
  10. TomTom GO 500 Display or Digitizer Replacement: step 10, image 1 of 3 TomTom GO 500 Display or Digitizer Replacement: step 10, image 2 of 3 TomTom GO 500 Display or Digitizer Replacement: step 10, image 3 of 3
    • Separate the display from the digitizer. The display is now fully removed from the device.
    Ask FixBot
6 other people completed this guide.
Jennie Chang
173 Reputation
1 Guide authored
UC Davis, Team 2-5, Oliver Fall 2016 Member of UC Davis, Team 2-5, Oliver Fall 2016
UCD-OLIVER-F16S2G5
5 Members
9 Guides authored
3 Guide Comments
If you keep the bezel and replace the glass, ensure the glass has adhesive before you buy.
Aaron - Reply Share
Do you have branch in Istanbul?
if yes please provide me the address. thaxs
Bsssam Kabeir - Reply Share
pertituire schermo e display cosa devo fare e comprare grazie
Cesare - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 41
All Time: 7,401
