Toloco EM26 Small Motherboard Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
115
All Time:
1,303
Comments: 3
3 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Is your massage gun not changing speed settings? This guide explains how to remove and replace the small motherboard located under the top cover plate. For this repair you will need a black spudger and phillips #00 screwdriver.
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
    1. Toloco EM26 Small Motherboard Replacement, Small Motherboard: step 1, image 1 of 2 Toloco EM26 Small Motherboard Replacement, Small Motherboard: step 1, image 2 of 2
      • Remove rubber pieces at the bottom of the massage gun’s barrel with the spudger by inserting it between the rubber and the plastic and use the tip of the spudger to pry the rubber out.
      Ask FixBot
    2. Toloco EM26 Small Motherboard Replacement: step 2, image 1 of 1
      • Remove the two 13.48 mm screws on the bottom of the massage gun with a Phillips #00 screwdriver.
      Ask FixBot
    3. Toloco EM26 Small Motherboard Replacement: step 3, image 1 of 2 Toloco EM26 Small Motherboard Replacement: step 3, image 2 of 2
      • Remove the 8.11 mm small black screw on the edge of circular plate with a Phillips #00 Screwdriver.
      Ask FixBot
    4. Toloco EM26 Small Motherboard Replacement: step 4, image 1 of 1
      • Take off the cap of the massage gun by simply lifting it off the device.
      • Be careful to secure the cap as the back part of the gun may fall.
      Ask FixBot
    5. Toloco EM26 Small Motherboard Replacement: step 5, image 1 of 2 Toloco EM26 Small Motherboard Replacement: step 5, image 2 of 2
      • Unplug the cable with the small plug from the small motherboard.
      Ask FixBot
    6. Toloco EM26 Small Motherboard Replacement: step 6, image 1 of 2 Toloco EM26 Small Motherboard Replacement: step 6, image 2 of 2
      • Remove the small motherboard for replacement.
      Ask FixBot
3 Guide Comments
How about large mother board replacement part?For a Toloco EM26 (2) connector’s on mother board.Display shows 00-99 from left to right
Raymond Van Alphen - Reply Share
What i did was disconnect the motherboard and wired the motor direct to the 12v power board. Cut the connector with Red, yellow, black wire to motherboard (12v power board). then cut the red, black connector to motherboard (motor). Then wire reds and blacks together (disable yellow), should fire up max speed but it works. They sale 12v dimmer switches but probably not worth doing because they are expensive.
Nords - Reply Share
Where can I buy a spare replacement for the motherboard
Warren Ochoa - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 115
All Time: 1,303
