Tokidos Play Cubes LED Repair guide
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
78
All Time:
457
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
How to repair when the screen goes nutters. This can also be used for repairing anything on this board, chasing LED, charging LED, button, etc
    1. Tokidos Play Cubes LED Repair guide, Open the play cube: step 1, image 1 of 2 Tokidos Play Cubes LED Repair guide, Open the play cube: step 1, image 2 of 2
      • Grab a tiny screwdriver. Flip over the cube. Unscrew the screws. Pretty straight forward so far. Put the screws somewhere where you won't lose them. This still has to be durable enough to handle your kids after we're all done.
      Ask FixBot
    2. Tokidos Play Cubes LED Repair guide, Disconnect the bottom: step 2, image 1 of 2 Tokidos Play Cubes LED Repair guide, Disconnect the bottom: step 2, image 2 of 2
      • Disconnect the JST cables. Don't disconnect the antenna running to the ESP. I mean, you can, but I've been warned it's a pain to reconnect and I respect that. It's also not necessary to get to the top part
      Ask FixBot
    3. Tokidos Play Cubes LED Repair guide, Unscrew the top: step 3, image 1 of 2 Tokidos Play Cubes LED Repair guide, Unscrew the top: step 3, image 2 of 2
      • Carefully unscrew the head. The biggest thing to watch out for is the spring. It is easily lost. It is magnetic FYI. Extra photo of the spring by itself should the need arise to identify.
      Ask FixBot
    4. Tokidos Play Cubes LED Repair guide, identify the broken wires and solder.: step 4, image 1 of 1
      • There are wires. The green and yellow were broken for me. Typically the green wire will be broken. Strip the wire. There's enough solder you can basically just press a tinned iron and melt and then it will just resolidify back in. I had to tape the top of the cord because I got a bit too wild with the soldering iron.
      • After you're done dump a 5 minute crafts level of hot glue over all the wires.....cause....kids
      Ask FixBot
    5. Tokidos Play Cubes LED Repair guide, Reassemble: step 5, image 1 of 1
      • Find that dang spring again. Reassemble. the front has a little groove so you can orient it right. Hidden technology, simple, sleek, effective.
      • The cables only connect one way so there's no reason to be concerned about orientation or position of the cables. The inny bits each have a unique outybit, marked by size or color.
      • Then screw with the screws that have not rolled off your desk. Hopefully all 4.
      Ask FixBot
    6. Tokidos Play Cubes LED Repair guide, Test.: step 6, image 1 of 1
      • Test. Make sure it works. Because if it doesn't your kids will cry.
      Ask FixBot
RaeL
490 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 78
All Time: 457
