Toilet Tree TTP-TRIM-1 Blade Replacement
    1. Toilet Tree TTP-TRIM-1 Blade Replacement, Battery: step 1, image 1 of 2 Toilet Tree TTP-TRIM-1 Blade Replacement, Battery: step 1, image 2 of 2
      • Twist the battery cap found on the bottom of the device counterclockwise.
      Ask FixBot
    2. Toilet Tree TTP-TRIM-1 Blade Replacement: step 2, image 1 of 1
      • Remove the battery
      Ask FixBot
    1. Toilet Tree TTP-TRIM-1 Blade Replacement, Trimmer Blades: step 3, image 1 of 2 Toilet Tree TTP-TRIM-1 Blade Replacement, Trimmer Blades: step 3, image 2 of 2
      • Twist the tip of the trimmer counterclockwise to remove it.
      • The trimmer blade assembly will be located on the inside of the tip.
      Ask FixBot
    2. Toilet Tree TTP-TRIM-1 Blade Replacement: step 4, image 1 of 2 Toilet Tree TTP-TRIM-1 Blade Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, pull the blade assembly out of the trimmer tip.
      Ask FixBot
samuel fontanez
301 Reputation
3 Guides authored
IUPUI, Team S1-G5, Harley Fall 2017 Member of IUPUI, Team S1-G5, Harley Fall 2017
IUPUI-HARLEY-F17S1G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 1,287
