Tools
Introduction
Go to step 1 ↓Improperly tightened handles are a common cause of flushing problems with toilets.
If your toilet is not flushing completely, check to see if you have a loose toilet handle. Loose handles can be tightened easily with an adjustable wrench.
If your toilet is running continuously, make sure your toilet handle isn't too tight. When the nut on a toilet handle is too tight, the handle arm won’t fall to its resting position after flushing. Make sure the handle has enough room to allow the arm to move freely. Tight handles can be loosened with an adjustable wrench.
Broken toilet handles will prevent a toilet from running at all and require replacement. Use this guide to replace the flush lever and tank lever on a traditional gravity flush toilet.
Squeeze open the spring clasp that connects the pull chain to the tank lever.
Disconnect the spring clasp from the tank lever.
Using an adjustable wrench, turn the locknut on the toilet handle clockwise until it loosens.
3 other people completed this guide.
