Toilet Flush Valve Seal Replacement
    1. Toilet Flush Valve Seal Replacement, Flush Valve Seal: step 1, image 1 of 1
      • This is the New Valve Seal used in this guide, available at hardware stores and home centers.
      • Using this New Seal installation shortcut method, it will NOT be necessary to do the following (of the original instructions that accompany the New Seal product): "Turn off water supply to toilet and drain tank" and "Unhook trip lever..." [any "chain" will need to be momentarily unhooked.] and "Unthread stop cap..." and "Lift float assembly off....."
      Ask FixBot
    2. Toilet Flush Valve Seal Replacement: step 2, image 1 of 1
      • Remove the top of the toilet tank.
      • With a towel nearby, roll-up your sleeves. Flush the toilet to lower the tank water level.
      • Immediately identify the old, worn [red] Valve Seal at bottom of the vertical assembly of Overflow Tube and Float.
      • Reach into water tank and remove the worn valve seal by pulling it, like an old rubber band, with your finger tips (or pliers) until it breaks.
      Ask FixBot
    3. Toilet Flush Valve Seal Replacement: step 3, image 1 of 1
      • Roll the new seal and stick it through the square trip lever holder and lasso the free end of the trip lever (the opposite end of the lever is attached to the flush lever outside of the tank).
      • Keeping the trip lever through large center hole of the new seal, pull the new seal in the reverse direction back through the square trip lever holder. Turn the trip lever holder as you do this to allow more space to ease the new seal back through.
      Ask FixBot
    4. Toilet Flush Valve Seal Replacement: step 4, image 1 of 3 Toilet Flush Valve Seal Replacement: step 4, image 2 of 3 Toilet Flush Valve Seal Replacement: step 4, image 3 of 3
      • When the new seal is between where the trip lever is connected to tank and where trip lever protrudes through square trip lever holder, for a moment, pull the flexible water refill tube out of the center of the stop cap. Point the free end of it down, as water may still be coming through it after flushing.
      • Take the new seal just over the stop cap and replace the water refill tube, being careful not to splash any water coming out of it.
      Ask FixBot
    5. Toilet Flush Valve Seal Replacement: step 5, image 1 of 1
      • Gently stretch and pull the new seal all the way down the vertical assembly of the overflow tube and float near the bottom and position it into its top groove of the flush valve.
      • Once in place, you should be able to gently grasp the edge of the new seal and turn it in place in the groove, around the base of the flush valve. Check the seal by flushing, watching and listening.
      Ask FixBot
    6. Toilet Flush Valve Seal Replacement: step 6, image 1 of 1
      • This is the reverse side of the Flush Valve Seal package.
      Ask FixBot
Flush Valve Seals will need to be replaced, at least, once every few years, depending on water condition. Other kinds of toilet water tanks may have similar assemblies. Why call a plumber for something so easy to do yourself?!
35 other people completed this guide.
Attached Documents
M J McAllister
1,981 Reputation
1 Guide authored
11 Guide Comments
I followed the instructions on the package (turn off water, disassemble the flush valve).
It was so simple, I think this "shortcut" would have been more difficult.
Sean Kennedy - Reply Share
You "think" it would have been more difficult? No disassembly (and reassembly) required on this one.
M J McAllister - Reply Share
I just followed this instruction and it was fixed in less than 2 minutes.
apexmi - Reply Share
After replacing seal, mine toilet is still leaking. :-(
Nina - Reply Share
Nina, most replacement gaskets leak. Try fluid master if you can find one but most of this stuff from China or Mexico and the manufacturing is faulty. See my other comment.
etmishts - Reply Share
Past 24 Hours: 21
Past 7 Days: 162
Past 30 Days: 1,018
All Time: 381,457
