Up to 20% off select tools
Tofu65 Key Switch Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
96
All Time:
919
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace a key switch on a Tofu65 keyboard with hot-swappable sockets. This is done by removing the old switch from the keyboard and replacing it with a new one. No soldering or prior experience is required to replace the switches.
    1. Tofu65 Key Switch Replacement, Key Switch: step 1, image 1 of 1
      • Unplug the power cord.
      Ask FixBot
    2. Tofu65 Key Switch Replacement: step 2, image 1 of 1
      • Remove the keycap by using a dedicated keycap remover or creating a hook-like tool with paperclips or using other tools.
      • Ensure that you pull it straight up without damaging the switch.
      Ask FixBot
    3. Tofu65 Key Switch Replacement: step 3, image 1 of 2 Tofu65 Key Switch Replacement: step 3, image 2 of 2
      • Clean the keycap either by swabbing the inside and outside with a wet cotton swab or submerging the keycap in a small container with warm water for 30 minutes.
      • Hand/dish soap can be used as well but not necessary.
      • Dry the keycaps.
      • DO NOT leave the keycaps in sunlight or else they could warp.
      Ask FixBot
    4. Tofu65 Key Switch Replacement: step 4, image 1 of 1
      • In order to remove the switch, locate the two switch housing pins near the top and bottom of the switch that hold it in the keyboard plate.
      Ask FixBot
    5. Tofu65 Key Switch Replacement: step 5, image 1 of 1
      • The switch can be removed with a dedicated switch remover or two small flat head screwdrivers.
      • Pinch the dedicated switch remover tool on the two housing pins or push them in with the two screwdrivers.
      Ask FixBot
    6. Tofu65 Key Switch Replacement: step 6, image 1 of 1
      • The switch should become loose.
      • Pull the switch straight up and out of the socket.
      Ask FixBot
    7. Tofu65 Key Switch Replacement: step 7, image 1 of 1
      • Before replacing the switch, ensure that the new switch does not have any bent pins.
      • If the pins are bent on the new switch, carefully bend them back so that they are pointing straight.
      Ask FixBot
    8. Tofu65 Key Switch Replacement: step 8, image 1 of 2 Tofu65 Key Switch Replacement: step 8, image 2 of 2
      • Line up the pins with the sockets on the keyboard.
      Ask FixBot
    9. Tofu65 Key Switch Replacement: step 9, image 1 of 1
      • Firmly push straight down.
      • The switch should click into place and should fit tightly in the keyboard plate.
      • Ensure that it is level and flush.
      Ask FixBot
    10. Tofu65 Key Switch Replacement: step 10, image 1 of 2 Tofu65 Key Switch Replacement: step 10, image 2 of 2
      • Pop the respective keycaps back onto the switch by pushing straight down and firmly so that the cap fits all the way onto the switch.
      • Make sure that there is no residual moisture as any moisture can leak into the keyboard and cause water damage/break the entire keyboard.
      Ask FixBot
Finish Line
Author
with
Hanlin Chen
181 Reputation
1 Guide authored
UC Davis, Team 1-3, Morris Winter 2023 Member of UC Davis, Team 1-3, Morris Winter 2023
UCD-MORRIS-W23S1G3
2 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 96
All Time: 919
