Up to 20% off select tools
Toastmaster TMHP2 Disassembly
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
70
All Time:
736
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 25 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If your Toastmaster TMHP2 Hot Pot is having trouble properly cooking, use this guide to get a lay out of the pot’s internal components. From there, you should be able to determine which component is defective.
Your hot pot receives power from a typical wall outlet through its white cord. A faulty cord will produce no power to the pot.
Be sure to test your hot pot before disassembly in order to confirm that it’s either working or not working. If the base appears to be heating up after the heat dial is turned, your hot pot is working! If not however, you will need to check the inside to determine the source for the hot pot’s defectivity.
Before disassembly, make sure the device is unplugged and turned off (not hot). Be careful when disassembling as there may be some pointy parts.
    1. Toastmaster TMHP2 Disassembly, Toastmaster TMHP2 Disassembly: step 1, image 1 of 1
      • Remove the lid and flip the pot over.
      Ask FixBot
    2. Toastmaster TMHP2 Disassembly: step 2, image 1 of 2 Toastmaster TMHP2 Disassembly: step 2, image 2 of 2
      • Use the plastic opening tool to remove the three rubber feet.
      Ask FixBot
    3. Toastmaster TMHP2 Disassembly: step 3, image 1 of 2 Toastmaster TMHP2 Disassembly: step 3, image 2 of 2
      • Using the Phillips #1 screwdriver, remove the three 11 mm screws from the bottom of the device.
      Ask FixBot
    4. Toastmaster TMHP2 Disassembly: step 4, image 1 of 2 Toastmaster TMHP2 Disassembly: step 4, image 2 of 2
      • Lift up the bottom cover to expose the internal wiring and components.
      Ask FixBot
    5. Toastmaster TMHP2 Disassembly: step 5, image 1 of 3 Toastmaster TMHP2 Disassembly: step 5, image 2 of 3 Toastmaster TMHP2 Disassembly: step 5, image 3 of 3
      • Using the Phillips #1 screwdriver, remove the two 8 mm screws securing the thermal switch.
      • Remove the bracket securing the thermal switch from the device.
      Ask FixBot
    6. Toastmaster TMHP2 Disassembly: step 6, image 1 of 3 Toastmaster TMHP2 Disassembly: step 6, image 2 of 3 Toastmaster TMHP2 Disassembly: step 6, image 3 of 3
      • Congratulations! You have disassembled the hot pot and can now see its internal compnents.
      Ask FixBot
Author
with
William Xia
233 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 70
All Time: 736
