Up to 20% off select tools
Tiptoi Pen 2nd Generation
Views: 16K
View statistics:
Past 24 Hours:
10
Past 7 Days:
88
Past 30 Days:
334
All Time:
16,174
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The 2nd generation Tiptoi pen suddenly stopped working.
Changing the battery and connecting it to the PC doesn't help, so I unscrew the part.
There is a flat connection cable from the electronics to the control unit, disconnect the cable and treat the contacts with contact spray, then the pen works again.
    1. Tiptoi Pen 2nd Generation, The connection cable in the control unit: step 1, image 1 of 1
      • Remove batteries
      Ask FixBot
    2. Tiptoi Pen 2nd Generation: step 2, image 1 of 1
      • Loosen the 4 screws with a small Phillips screwdriver.
      • Open the case.
      Ask FixBot
    3. Tiptoi Pen 2nd Generation: step 3, image 1 of 1
      • Carefully fold the black plastic part upwards, then pull out the flat cable with tweezers.
      • Treat the connector with contact spray.
      • Carefully insert the flat cable again, with the blue marking facing upwards, fold the black plastic part down again.
      • Put the pen back together.
      Ask FixBot
Reverse the steps to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Peter Müller
157 Reputation
1 Guide authored
1 Guide Comment
1000Dank!!!! Sie sind super😙
Inhibisa S - Reply Share
Past 24 Hours: 10
Past 7 Days: 88
Past 30 Days: 334
All Time: 16,174
