Timex Ironman Triathlon Battery Replacement
  1. Timex Ironman Triathlon Battery Replacement, Remove Strap From: step 1, image 1 of 3 Timex Ironman Triathlon Battery Replacement, Remove Strap From: step 1, image 2 of 3 Timex Ironman Triathlon Battery Replacement, Remove Strap From: step 1, image 3 of 3
    • Use small flat tool such as a Flathead screwdriver to press the metal "spring bars" inward, one at a time, to release the wrist-band from the "Lugs."
    • Repeat first step on opposite side.
    Ask FixBot
  2. Timex Ironman Triathlon Battery Replacement, Removing Backplate: step 2, image 1 of 3 Timex Ironman Triathlon Battery Replacement, Removing Backplate: step 2, image 2 of 3 Timex Ironman Triathlon Battery Replacement, Removing Backplate: step 2, image 3 of 3
    • Remove screws the 4 screws using #000 Philips Bit.
    • Carefully remove back-plate, and lay it on its back.
    Ask FixBot
  3. Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: step 3, image 1 of 3 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: step 3, image 2 of 3 Timex Ironman Triathlon Battery Replacement, Removing Contact-Plate: step 3, image 3 of 3
    • Use JIS #000 Bit to unscrew the screw that secures the 2025 coin-cell battery underneath the white sticker.
    • Remove the screw from the eyelet, and place it to the side in a safe place.
    Ask FixBot
  4. Timex Ironman Triathlon Battery Replacement: step 4, image 1 of 3 Timex Ironman Triathlon Battery Replacement: step 4, image 2 of 3 Timex Ironman Triathlon Battery Replacement: step 4, image 3 of 3
    • Carefully lift contact-bracket up and peel dead battery off, for recycling.
    • Unlatch the empty contact-bracket by gently lifting the bracket up, off, and away from the plastic knuckle that is holding it onto the body of the watch.
    • Place contact-bracket face-up on a secure surface.
    • Place the positive(+) side of the new battery facing down on the contact-bracket.
    Ask FixBot
  5. Timex Ironman Triathlon Battery Replacement, Secure New Battery: step 5, image 1 of 2 Timex Ironman Triathlon Battery Replacement, Secure New Battery: step 5, image 2 of 2
    • Carefully replace contact-bracket by hanging the metal latch over the plastic knuckle.
    • Tighten screw.
    • Reset system settings by touching both gold pins with a conductive tool, such as the tip of a small Flathead screwdriver, or tweezers.
    Ask FixBot
  6. Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: step 6, image 1 of 3 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: step 6, image 2 of 3 Timex Ironman Triathlon Battery Replacement, Secure Back-Plate: step 6, image 3 of 3
    • Replace back-plate with logo facing same orientation as watch-face.
    • Replace and tighten screws from Step 2 with Bit #000, starting diagonally to create maximum water-resistance.
    Ask FixBot
To reassemble your device, follow these steps in reverse, but remember to replace screws in a diagonal order to create a tight seal, and improve water-resistance.
3 other people completed this guide.
Phoenixwa
283 Reputation
2 Guides authored
1 Guide Comment
Forgot to tell people to put the strap back. (In my opinion the hardest part)
Ben Hingley - Reply Share
Past 24 Hours: 9
Past 7 Days: 59
Past 30 Days: 219
All Time: 3,032
