Timbuk2 Suitcase Roller Handle Replacement
Views: 6.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
37
Past 30 Days:
206
All Time:
6,860
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. Timbuk2 Suitcase Roller Handle Replacement, Roller Handle: step 1, image 1 of 1
      • Here are the tools you will need:
      • New roller handle set
      • Screwdriver
      • 4mm Allen wrench
      Ask FixBot
    2. Timbuk2 Suitcase Roller Handle Replacement: step 2, image 1 of 1
      • Open luggage and unzip backing, exposing back of roller. Using an Allen wrench, unscrew all 10 screws along the bottom plate and remove plastic coverings
      Ask FixBot
    3. Timbuk2 Suitcase Roller Handle Replacement: step 3, image 1 of 1
      • Turn luggage over and using Allen wrench, unscrew all 8 bolts on the back of luggage handle assembly. Remove handle frame from luggage body
      Ask FixBot
      • Put the new roller handle set in place. Repeat steps 2 and 3 in the opposite order.
      • You're finished!
      Ask FixBot
Finish Line
Emilee
1,681 Reputation
9 Guides authored
3 Guide Comments
Excuse me, but there's nothing in these instructions about removing the wheels from the old assembly and installing them on the new one? Can someone please supply those instructions so that I can complete this assembly? Thanks much!
robin - Reply Share
Agree, I also found this step missing. It should be “step 3.5”. Moving the wheels to the new handle is where the screw driver comes in. After the handle is detached from the case, there are two small philips head screws that must be removed, one next to each wheel. After the screws are out, the wheels pull out from the tube of the old handle, and can be moved to the new handle. After pushing the wheels back into the new handle, align the tab of the plastic wheels into the indentation on the tube of the handle. Once aligned, the screw hole should be visible. Put the screws back in and you’re ready for step 4, reconnecting the handle to the bag.
stevenfry - Reply Share
the wheel replacement instructions:
Timbuk2 Suitcase Roller Wheel and/or Hub Replacement
Rick - Reply Share
Past 24 Hours: 2
Past 7 Days: 37
Past 30 Days: 206
All Time: 6,860
