Tigerbox 1203 USB-C Port Repair
Views: 2.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
67
Past 30 Days:
277
All Time:
2,436
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
These instructions explain how to replace a faulty USB-C port on the Tigermedia Tigerbox with a new one.
    1. Tigerbox 1203 USB-C Port Repair, Replacing the USB-C port: step 1, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Replacing the USB-C port: step 1, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Replacing the USB-C port: step 1, image 3 of 3
      • We start at the bottom of the Tigerbox and loosen the five Phillips-head screws using a suitable PH00 screwdriver
      Ask FixBot
    2. Tigerbox 1203 USB-C Port Repair, Remove the bottom cover: step 2, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Remove the bottom cover: step 2, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Remove the bottom cover: step 2, image 3 of 3
      • Next, remove the cover and unscrew the remaining Phillips-head screws
      Ask FixBot
    3. Tigerbox 1203 USB-C Port Repair, Remove the connector: step 3, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Remove the connector: step 3, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Remove the connector: step 3, image 3 of 3
      • Once this is done, we carefully use tweezers to remove the connector cable for the bottom panel and slowly lift the dock connector out of the housing. Another connector cable becomes visible
      Ask FixBot
    4. Tigerbox 1203 USB-C Port Repair, Remove the remaining connector: step 4, image 1 of 2 Tigerbox 1203 USB-C Port Repair, Remove the remaining connector: step 4, image 2 of 2
      • Once this connector has been removed, the dock connector is exposed, and you must remove two more screws from the dock connector before you can access the connector board.
      Ask FixBot
    5. Tigerbox 1203 USB-C Port Repair, Disassembling the Dock Connector: step 5, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Disassembling the Dock Connector: step 5, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Disassembling the Dock Connector: step 5, image 3 of 3
      • Now remove the two screws and take out the circuit board along with the charging port.
      Ask FixBot
    6. Tigerbox 1203 USB-C Port Repair, Removing the USB-C port: step 6, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Removing the USB-C port: step 6, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Removing the USB-C port: step 6, image 3 of 3
      • Let's now turn our attention to the USB-C port. Thei can be purchased on eBay for around 5 EUR, for example. The port should be heated with a heat gun to loosen it. A temperature of approximately 320° C and a higher airflow setting are recommended
      Ask FixBot
    7. Tigerbox 1203 USB-C Port Repair, Preparing and Soldering the New Charging Port: step 7, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Preparing and Soldering the New Charging Port: step 7, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Preparing and Soldering the New Charging Port: step 7, image 3 of 3
      • Once the defective USB-C port has been removed, clean the contact surfaces and apply fresh solder and flux. Then solder the new port in place.
      Ask FixBot
    8. Tigerbox 1203 USB-C Port Repair, Reassembly: step 8, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Reassembly: step 8, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Reassembly: step 8, image 3 of 3
      • With the new port in place, you can begin reassembling all the parts.
      Ask FixBot
    9. Tigerbox 1203 USB-C Port Repair, Conclusion: step 9, image 1 of 3 Tigerbox 1203 USB-C Port Repair, Conclusion: step 9, image 2 of 3 Tigerbox 1203 USB-C Port Repair, Conclusion: step 9, image 3 of 3
      • Once everything is back lin place, you have a repaired Tigerbox! Congratulations!
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 67
Past 30 Days: 277
All Time: 2,436
