TicWatch Pro 3 GPS Motherboard Replacement
  1. TicWatch Pro 3 GPS Motherboard Replacement, Power down your watch: step 1, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Power down your watch: step 1, image 2 of 2
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
    Ask FixBot
  2. TicWatch Pro 3 GPS Motherboard Replacement, Unfasten the back cover: step 2, image 1 of 1
    • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
    Ask FixBot
  3. TicWatch Pro 3 GPS Motherboard Replacement, Loosen the back cover adhesive: step 3, image 1 of 1
    • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
    Ask FixBot
  4. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: step 4, image 1 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: step 4, image 2 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the back cover assembly: step 4, image 3 of 3
    • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
    • Pry upwards to loosen the back cover assembly. This may require some force.
    • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
    • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
    Ask FixBot
  5. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the sensor assembly cable: step 5, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the sensor assembly cable: step 5, image 2 of 2
    • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Ask FixBot
  6. TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: step 6, image 1 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: step 6, image 2 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Remove the back cover assembly: step 6, image 3 of 3
    • Remove the back cover assembly.
    Ask FixBot
  7. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the microphone cable: step 7, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the microphone cable: step 7, image 2 of 2
    • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
    Ask FixBot
  8. TicWatch Pro 3 GPS Motherboard Replacement, Unfasten the core assembly: step 8, image 1 of 1
    • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
    Ask FixBot
  9. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the core assembly: step 9, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the core assembly: step 9, image 2 of 2
    • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
    • Pry upwards to loosen the core assembly.
    • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
    Ask FixBot
  10. TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: step 10, image 1 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: step 10, image 2 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Swing open the core assembly: step 10, image 3 of 3
    • Carefully swing open the core assembly like the front cover of a book.
    • Avoid straining or tearing the display cables at the bottom of the core assembly.
    Ask FixBot
  11. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: step 11, image 1 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: step 11, image 2 of 3 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the display cables: step 11, image 3 of 3
    • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
    Ask FixBot
  12. TicWatch Pro 3 GPS Motherboard Replacement, Remove the core assembly: step 12, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the core assembly: step 12, image 2 of 2
    • Remove the core assembly.
    Ask FixBot
  13. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the interconnect cable: step 13, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the interconnect cable: step 13, image 2 of 2
    • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
    Ask FixBot
  14. TicWatch Pro 3 GPS Motherboard Replacement, Remove the daughterboard: step 14, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the daughterboard: step 14, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the daughterboard.
    Ask FixBot
  15. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the battery: step 15, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the battery: step 15, image 2 of 2
    • The battery is held in place by mild adhesive.
    • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Pry upwards to loosen the battery.
    • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
    • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
    Ask FixBot
  16. TicWatch Pro 3 GPS Motherboard Replacement, Reposition the battery: step 16, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Reposition the battery: step 16, image 2 of 2
    • Carefully fold the battery over to gain access to the battery cable connector.
    • Avoid straining or tearing the battery cable.
    Ask FixBot
  17. TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the battery: step 17, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Disconnect the battery: step 17, image 2 of 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Ask FixBot
  18. TicWatch Pro 3 GPS Motherboard Replacement, Remove the battery: step 18, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the battery: step 18, image 2 of 2
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
    Ask FixBot
  19. TicWatch Pro 3 GPS Motherboard Replacement, Remove the interconnect cable: step 19, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the interconnect cable: step 19, image 2 of 2
    • Remove the interconnect cable.
    Ask FixBot
  20. TicWatch Pro 3 GPS Motherboard Replacement, Pry up the motherboard: step 20, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Pry up the motherboard: step 20, image 2 of 2
    • Insert the point of a spudger between the midframe and the motherboard.
    • Pry upwards to loosen the motherboard.
    Ask FixBot
  21. TicWatch Pro 3 GPS Motherboard Replacement, Remove the motherboard: step 21, image 1 of 2 TicWatch Pro 3 GPS Motherboard Replacement, Remove the motherboard: step 21, image 2 of 2
    • Remove the motherboard.
    Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
4 other people completed this guide.
Dominik Schnabelrauch
260,878 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,612 Guides authored
5 Guide Comments
Hi there , just disassembled the motherboard no issues, i wanted to see what was wrong with the watch and its atleast from what i can tell water damage to the motherboard, can anyone help me find a replacement ? I'm struggling with that
iballisticgiannakos - Reply Share
Hi, have you found a replacement? The second display is the one that is failing for me. Thank you.
Walter Guerrero - Reply Share
IP68 ... haha. Also water damage here. It's so small, that I needed to remove the mainboard to finally see it.
This is the 2nd TicWatch that was failing...
Any idea where to get a proper and working replacement motherboard? Ebay has a few, but that are all marked as "defective" --> useless.
Alex C. - Reply Share
This fixed the small dark spot near the seconds digits (Essential mode). Some said it was a expanded battery, but upon disassembly the battery was still completely flat, so no dice there. However, I've reassembled the watch with all screws loosely tightened and it fixed it. Of course not waterproof anymore, but at least the display won't damage itself now. The spot disappeared completely.
Valentino - Reply Share
I have 2 tw pro 3 . 1st one water damaged cause 2nd display not to work and watch goes into freeze mode . The 2nd tw motherboard completely dead . Struggling to find motherboards for these watches . Any suggestions?
Rashied Johnson - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 39
All Time: 2,235
