TicWatch Pro 3 GPS Battery Replacement
Views: 36K
View statistics:
Past 24 Hours:
14
Past 7 Days:
93
Past 30 Days:
417
All Time:
36,191
Comments: 34
13 comments on steps, 21 guide comments.
Go to guide comments
Completed: 49
49 people have marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 - 50 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your TicWatch Pro 3 GPS.
For your safety, discharge the battery below 25% before disassembling your watch. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling the device. Your device will function normally, but will lose its IP (Ingress Protection) rating.
Tools
    1. TicWatch Pro 3 GPS Battery Replacement, Power down your watch: step 1, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Power down your watch: step 1, image 2 of 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Ask FixBot
    2. TicWatch Pro 3 GPS Battery Replacement, Unfasten the back cover: step 2, image 1 of 1
      • Use a Torx T3 screwdriver to remove the four 4.1 mm-long screws securing the back cover.
      Ask FixBot
    3. TicWatch Pro 3 GPS Battery Replacement, Loosen the back cover adhesive: step 3, image 1 of 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    4. TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: step 4, image 1 of 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: step 4, image 2 of 3 TicWatch Pro 3 GPS Battery Replacement, Pry up the back cover assembly: step 4, image 3 of 3
      • Insert the flat end of a spudger into the microphone opening at the top edge of the back cover.
      • Pry upwards to loosen the back cover assembly. This may require some force.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the daughterboard.
      • Swing the back cover assembly open by 45 degrees to gain access to the sensor assembly cable.
      Ask FixBot
    5. TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: step 5, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the sensor assembly cable: step 5, image 2 of 2
      • Use a spudger to disconnect the sensor assembly cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    6. TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: step 6, image 1 of 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: step 6, image 2 of 3 TicWatch Pro 3 GPS Battery Replacement, Remove the back cover assembly: step 6, image 3 of 3
      • Remove the back cover assembly.
      Ask FixBot
    1. TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: step 7, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the microphone cable: step 7, image 2 of 2
      • Use a spudger to disconnect the microphone cable by prying the connector straight up from its socket.
      Ask FixBot
    2. TicWatch Pro 3 GPS Battery Replacement, Unfasten the core assembly: step 8, image 1 of 1
      • Use a Phillips screwdriver to remove the three 4.1 mm-long screws securing the core assembly.
      Ask FixBot
    3. TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: step 9, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the core assembly: step 9, image 2 of 2
      • Insert the point of a spudger between the right edge of the core assembly and the watch frame.
      • Pry upwards to loosen the core assembly.
      • Don't try to remove the core assembly all the way yet. It's still connected to the screen.
      Ask FixBot
    4. TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: step 10, image 1 of 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: step 10, image 2 of 3 TicWatch Pro 3 GPS Battery Replacement, Swing open the core assembly: step 10, image 3 of 3
      • Carefully swing open the core assembly like the front cover of a book.
      • Avoid straining or tearing the display cables at the bottom of the core assembly.
      Ask FixBot
    5. TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: step 11, image 1 of 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: step 11, image 2 of 3 TicWatch Pro 3 GPS Battery Replacement, Disconnect the display cables: step 11, image 3 of 3
      • Use a spudger to disconnect the screen and the digitizer cables by prying the connectors straight up from their sockets.
      Ask FixBot
    6. TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: step 12, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Remove the core assembly: step 12, image 2 of 2
      • Remove the core assembly.
      Ask FixBot
    1. TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: step 13, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the interconnect cable: step 13, image 2 of 2
      • Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
      Ask FixBot
    2. TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: step 14, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Remove the daughterboard: step 14, image 2 of 2
      Tool used on this step:
      Buy
      • Use a pair of tweezers to remove the daughterboard.
      Ask FixBot
    3. TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: step 15, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Pry up the battery: step 15, image 2 of 2
      • The battery is held in place by mild adhesive.
      • Insert the flat end of a spudger between the bottom edge of the battery and the midframe.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Pry upwards to loosen the battery.
      • If you're struggling to pry up the battery, place a heated iOpener onto the motherboard to loosen the adhesive underneath. Don't apply the iOpener directly onto the battery.
      • Don't try to remove the battery all the way yet. It's still connected to the motherboard.
      Ask FixBot
    4. TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: step 16, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Reposition the battery: step 16, image 2 of 2
      • Carefully fold the battery over to gain access to the battery cable connector.
      • Avoid straining or tearing the battery cable.
      Ask FixBot
    5. TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: step 17, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Disconnect the battery: step 17, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      Ask FixBot
    6. TicWatch Pro 3 GPS Battery Replacement, Remove the battery: step 18, image 1 of 2 TicWatch Pro 3 GPS Battery Replacement, Remove the battery: step 18, image 2 of 2
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch Pro 3 answers community for help.
49 other people completed this guide.
Dominik Schnabelrauch
266,627 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
121 Members
72,931 Guides authored
21 Guide Comments
Where did you buy a replacement battery (if you did)? I have scoured thru aliexpress, ebay, and tried to find shattered-screen watches I could transplant from, with no luck so far. I guess I'll keep looking. My watch barely lasted a year before the battery life halved. The voltage sag is so bad the watch bootloops whenever it vibrates below 30% voltage.
George - Reply Share
I've found a listing in aliexpress for an aftermarket battery but need to de-solder the original BMS and transfer to this new battery. Here's the link to aliexpress.
https://www.aliexpress.com/item/10050049...
Daniel Lee - Reply Share
I don't think it's tin welding, but most likely TIG welding.
Difficult to open it, but the less experienced could solder the battery contacts on the top without opening the old solder.
https://imgur.com/zhFXcQ4
https://imgur.com/cKJb137
marco deirossi - Reply Share
A small problem (solved) that I encountered with the battery purchased as compatible from ali-express is the greater ( >5mm)
distance (compared to the battery) of the original two poles of the battery.
You have to bend them carefully inwards to be able to weld them afterwards.
https://imgur.com/5mrfzDk
https://imgur.com/v2OCVCc
https://imgur.com/Izw3dU1
https://imgur.com/QsnAN6I
Past 24 Hours: 14
Past 7 Days: 93
Past 30 Days: 417
All Time: 36,191
