Up to 20% off select tools
TicWatch E3 Battery Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
148
All Time:
3,770
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the battery in your TicWatch E3.
For your safety, discharge the battery below 25% before disassembling your watch. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
You’ll need replacement adhesive when reassembling the device. Your device will function normally, but will lose its IP (Ingress Protection) rating.
    1. TicWatch E3 Battery Replacement, Power down your watch: step 1, image 1 of 2 TicWatch E3 Battery Replacement, Power down your watch: step 1, image 2 of 2
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Ask FixBot
    2. TicWatch E3 Battery Replacement, Loosen the adhesive: step 2, image 1 of 1
      • Apply a heated iOpener to the rear side of the watch for 5 minutes to loosen the adhesive underneath.
      • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
      Ask FixBot
    3. TicWatch E3 Battery Replacement, Insert an opening pick: step 3, image 1 of 3 TicWatch E3 Battery Replacement, Insert an opening pick: step 3, image 2 of 3 TicWatch E3 Battery Replacement, Insert an opening pick: step 3, image 3 of 3
      • Insert an opening pick into the recess between the watch frame and the top edge of the back cover.
      • Push the opening pick to create a gap between the back cover and the watch frame.
      Ask FixBot
    4. TicWatch E3 Battery Replacement, Pry up the back cover assembly: step 4, image 1 of 3 TicWatch E3 Battery Replacement, Pry up the back cover assembly: step 4, image 2 of 3 TicWatch E3 Battery Replacement, Pry up the back cover assembly: step 4, image 3 of 3
      • Twist the opening pick to widen the gap between the back cover assembly and the watch frame.
      • Pry upward to loosen the back cover assembly.
      • Don't try to remove the back cover assembly all the way yet. It's still connected to the motherboard.
      Ask FixBot
    5. TicWatch E3 Battery Replacement, Free the back cover assembly: step 5, image 1 of 2 TicWatch E3 Battery Replacement, Free the back cover assembly: step 5, image 2 of 2
      • Carefully lift up the bottom edge of the back cover assembly to make sure it isn't adhered to the watch frame anymore.
      • Avoid straining or tearing the sensor or battery cables.
      Ask FixBot
    6. TicWatch E3 Battery Replacement, Open the watch: step 6, image 1 of 2 TicWatch E3 Battery Replacement, Open the watch: step 6, image 2 of 2
      • Grab the back cover assembly and carefully bring it into an upright position next to the watch housing.
      Ask FixBot
    7. TicWatch E3 Battery Replacement, Disconnect the battery cable: step 7, image 1 of 2 TicWatch E3 Battery Replacement, Disconnect the battery cable: step 7, image 2 of 2
      • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    8. TicWatch E3 Battery Replacement, Disconnect the sensor cable: step 8, image 1 of 2 TicWatch E3 Battery Replacement, Disconnect the sensor cable: step 8, image 2 of 2
      • Use a spudger to disconnect the sensor cable by prying the connector straight up from its socket.
      Ask FixBot
    9. TicWatch E3 Battery Replacement, Remove the back cover assembly: step 9, image 1 of 2 TicWatch E3 Battery Replacement, Remove the back cover assembly: step 9, image 2 of 2
      • Remove the back cover assembly.
      Ask FixBot
    1. TicWatch E3 Battery Replacement, Loosen the battery adhesive: step 10, image 1 of 1
      • Apply a heated iOpener to the back cover for 2 minutes to loosen the adhesive underneath the battery.
      Ask FixBot
    2. TicWatch E3 Battery Replacement, Free the battery cable: step 11, image 1 of 3 TicWatch E3 Battery Replacement, Free the battery cable: step 11, image 2 of 3 TicWatch E3 Battery Replacement, Free the battery cable: step 11, image 3 of 3
      • Reposition the battery and sensor assembly cables by folding the battery cable to the left and then the sensor cable to the right side of the back cover assembly.
      • Do not bend the cables sharply to avoid cable damage.
      Ask FixBot
    3. TicWatch E3 Battery Replacement, Pry up the battery: step 12, image 1 of 2 TicWatch E3 Battery Replacement, Pry up the battery: step 12, image 2 of 2
      • Insert the flat end of a spudger underneath the bottom edge of the battery.
      • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
      • Pry upwards to loosen the battery.
      Ask FixBot
    4. TicWatch E3 Battery Replacement, Remove the battery: step 13, image 1 of 3 TicWatch E3 Battery Replacement, Remove the battery: step 13, image 2 of 3 TicWatch E3 Battery Replacement, Remove the battery: step 13, image 3 of 3
      • Remove the battery.
      • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
      • Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the device at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
During reassembly, apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our TicWatch E3 answers community for help.
4 other people completed this guide.
Dominik Schnabelrauch
268,208 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
3 Guide Comments
Dear Dominik thanks a lot for your useful help. Can you please tell me where I can buy a new battery for the ticwatch E3, internet doesn’t seem to help much. Thanks in advance.
Riccardo Lo Bianco - Reply Share
It is on Ali Express
Mahmoud Moheb - Reply Share
Where can I buy a replacement battery for the tic watch e3
Dave Bissett - Reply Share
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 148
All Time: 3,770
