Up to 20% off select tools
TiVo Bolt Hard Drive Replacement
Views: 29K
View statistics:
Past 24 Hours:
7
Past 7 Days:
63
Past 30 Days:
219
All Time:
28,802
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
There are currently two methods being used to upgrade/replace TiVo Bolt HDDs. One is replacing the internal 2.5" drive, the other is using a 3.5" drive by drilling a hole in the casing and using a sata extension cable and providing an external power source as well as a separate housing. TiVos are particular about what type of HDD is used. The parts section included the most popular choices for internal HDD replacement options. This Guide will cover replacing the internal 2.5" HDD with another 2.5" HDD. You can use a drive greater than 3tb however the TiVo box will not auto format it. This Guide will not cover how to format a HDD for use in a TiVo if it is over 3tb.
    1. TiVo Bolt Hard Drive Replacement, Remove the Torx Screw on the Back: step 1, image 1 of 1
      • This screw is a different length than all the other screws.
      Ask FixBot
    2. TiVo Bolt Hard Drive Replacement, Remove Cable Card cover: step 2, image 1 of 1
      • Undo the clips to lift up the Cable card slot cover
      Ask FixBot
    3. TiVo Bolt Hard Drive Replacement, Undo 2 Screws holding the case to the board/base: step 3, image 1 of 1
      • Do not attempt to remove the housing yet. Still 3 more screws and plastic clips holding it in place
      Ask FixBot
    4. TiVo Bolt Hard Drive Replacement, Remove the HDD Cover: step 4, image 1 of 2 TiVo Bolt Hard Drive Replacement, Remove the HDD Cover: step 4, image 2 of 2
      • This shows the placement of the clips so you know where to place your plastic pics.
      • Make sure to left this cover straight up when removing as you can see on the left side it has prongs that slide into the other part of the plastic housing.
      Ask FixBot
    5. TiVo Bolt Hard Drive Replacement, Remove 3 Remaining Screws Holding Case to Board: step 5, image 1 of 2 TiVo Bolt Hard Drive Replacement, Remove 3 Remaining Screws Holding Case to Board: step 5, image 2 of 2
      • Case is still clipped in so do not attempt to remove the case yet
      Ask FixBot
    6. TiVo Bolt Hard Drive Replacement, Remove the Plastic Housing: step 6, image 1 of 2 TiVo Bolt Hard Drive Replacement, Remove the Plastic Housing: step 6, image 2 of 2
      • Plastic Pic placement shows where the clips are.
      • I found it easy to use a 5th pic on the right to help separate the housing from the board
      Ask FixBot
    7. TiVo Bolt Hard Drive Replacement, Remove Screw holding HDD Tray to the Board: step 7, image 1 of 1
      • Once you undo this screw you can unplug the harddrive and left up the HDD to separate the HDD and tray from the Board
      • Then undo the screws holding the tray to the HDD. Put the Tray on you new HDD and screw it in.
      Ask FixBot
    8. TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: step 8, image 1 of 3 TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: step 8, image 2 of 3 TiVo Bolt Hard Drive Replacement, Final Pictures of the board with the new HDD: step 8, image 3 of 3
      • Afterwards I decided to go ahead and add the plastic routing clips on, which are not shown in the picture.
      Ask FixBot
15 other people completed this guide.
Author
with
Jacob
617 Reputation
1 Guide authored
8 Guide Comments
I’m using a bolt+. One thing I couldn’t figure out how to do was step 4 without breaking the clips for the HDD cover. Even though they snapped off, it’s generally not a big deal, and will actually make it easier the next time to take the thing apart. One thing I noticed about the design is the cooling is terrible. The fan is placed in an off-center area where it sucks air in and the pressure forces it to blow out the bottom. In addition, the HDD is sitting on top of a sealed area and has no airflow. For those with hard drive failures, heat is likely the culprit in this case…poor design. I’m not even gonna put the HDD cover back on. Instead I' have some 80mm usb powered fans I’m just gonna have blow straight into the side of the bolt across the HDD.
Gman - Reply Share
Hello. Just wanted to send you this interesting article from backblaze about hard drive failure in relationship to heat. I am not disagreeing with you I think the heat distribution design does not work very well as I have also done the same thing and added a usb powered fan to the bottom of the TiVo. And since you seem to be interested in taking apart your TiVo. I’ll leave these articles here about using SSDs in DVRs. You may find it an interesting read. Link 1 and Link 2.
Jacob - Reply Share
Any update to supported HDDs as the ones listed are no longer available?
Jerry D - Reply Share
Very nice guide! Thank you, Jacob! I thought for sure I broke off those HDD cover tabs. They let loose with a mighty CRACK, but to my surprise, they were all intact. I replaced the existing bad HDD with a Toshiba 2TB (MQ03ABB200). Put everything back together, plugged it in and got the start up screen. It sat there for a while, formatting the HDD I assume, and then it went to the guided set up. It works perfectly now. So thankful for this guide!
Kieran Ecker - Reply Share
Hi Kieran, how long did it take to format the HDD? Was there any indication as to how long to expect, like a timer or progress bar? Thanks for any advice you have.
zekeotsuka - Reply Share
Past 24 Hours: 7
Past 7 Days: 63
Past 30 Days: 219
All Time: 28,802
