Up to 20% off select tools
Thrustmaster T3PM Maintenance
Views: 2.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
25
Past 30 Days:
120
All Time:
2,157
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
How to disassemble the T3PM pedal set, clean it and keep it in the best possible condition.
    1. Thrustmaster T3PM Maintenance, Disconnect the pedal heads: step 1, image 1 of 2 Thrustmaster T3PM Maintenance, Disconnect the pedal heads: step 1, image 2 of 2
      • Unscrew all 6 screws from the pedal heads
      • Note the positioning of the pedal heads or take this opportunity to try out new position
      • Before starting, unplug your T3PM.
      Ask FixBot
    2. Thrustmaster T3PM Maintenance, Remove screws from the bottom: step 2, image 1 of 1
      • Using Phillips screwdriver remove all screws at the bottom.
      Ask FixBot
    3. Thrustmaster T3PM Maintenance, Remove the top cover: step 3, image 1 of 1
      • Remove the top cover and put it aside
      Ask FixBot
      • Clean off any dust, residue, pet hair and other foreign debris that has accumulated inside the pedal set.
      Ask FixBot
    4. Thrustmaster T3PM Maintenance, Inspect the wires and tape.: step 5, image 1 of 2 Thrustmaster T3PM Maintenance, Inspect the wires and tape.: step 5, image 2 of 2
      • Make sure that the wires and the main cable are secure.
      • Replace sticky tape if necessary.
      Ask FixBot
    5. Thrustmaster T3PM Maintenance, Thoroughly clean each pedal.: step 6, image 1 of 1
      • Clean off any dust, residue, pet hair etc from the pedals themselves, near the sensors and springs.
      • Make sure to clean off the extremities of the pedals.
      Ask FixBot
    6. Thrustmaster T3PM Maintenance, Clean the sensors: step 7, image 1 of 2 Thrustmaster T3PM Maintenance, Clean the sensors: step 7, image 2 of 2
      • Using an air-blower, compressed air-can or other tool, clean the sensors.
      • Be cautions as to not damage the sensors, wires or the connectors.
      • Watch out for Electro-static Discharge. Make sure not to touch the sensors or use anti-static wrist strap.
      Ask FixBot
    7. Thrustmaster T3PM Maintenance, Inspect the springs.: step 8, image 1 of 1
      • Inspect the conditions of the gas and clutch springs.
      • Re-lubricate if necessary.
      Ask FixBot
To reassemble your device, follow the steps 1,2,3 in reverse order.
Author
with
Formica Fusca
2,626 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 25
Past 30 Days: 120
All Time: 2,157
