Up to 20% off select tools
Thrustmaster T3PA Cable Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
28
Past 30 Days:
124
All Time:
2,207
Comments: 1
1 comment on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 7 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
    1. Thrustmaster T3PA Cable Replacement, Cable: step 1, image 1 of 3 Thrustmaster T3PA Cable Replacement, Cable: step 1, image 2 of 3 Thrustmaster T3PA Cable Replacement, Cable: step 1, image 3 of 3
      • Start by flipping it over, rest it on the pedals. make sure the wire is pointing towards the bottom. remove the 14 Screws on the back with a PH2 Phillips head screwdriver and carefully pop it off.
      • (DO NOT COMPLETELY PULL IT OFF BECAUSE OF WIRES.)
      Ask FixBot
    2. Thrustmaster T3PA Cable Replacement: step 2, image 1 of 2 Thrustmaster T3PA Cable Replacement: step 2, image 2 of 2
      • Unplug the wire connected to the bottom (the one circled in the image).
      Ask FixBot
    3. Thrustmaster T3PA Cable Replacement: step 3, image 1 of 2 Thrustmaster T3PA Cable Replacement: step 3, image 2 of 2
      • Once the bottom is separated, remove the glue holding the wire and pull it out.
      Ask FixBot
For reassembly, simply follow the steps in reverse.
3 other people completed this guide.
Author
with
John.gmot
384 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 28
Past 30 Days: 124
All Time: 2,207
