Thrustmaster T Flight Hotas 4 Trigger Replacement
    1. Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: step 1, image 1 of 2 Thrustmaster T Flight Hotas 4 Trigger Replacement, J1 Screws on Joystick Handle: step 1, image 2 of 2
      • Be sure to disconnect the controller from the power source before disassembling.
      • Remove the four 15 mm J1 JIS head screws from the exterior of the joystick.
      Ask FixBot
    1. Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: step 2, image 1 of 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: step 2, image 2 of 3 Thrustmaster T Flight Hotas 4 Trigger Replacement, Trigger: step 2, image 3 of 3
      • Carefully remove the paneling of the joystick using your hands to pull the panels apart.
      • Be aware that the panels will fall apart when the screws are removed unless they are held together.
      • This metal piece must be put back into its correct position. If not it will impair the movement of the joystick's rudder mechanism.
      Ask FixBot
    2. Thrustmaster T Flight Hotas 4 Trigger Replacement: step 3, image 1 of 1
      • Remove the 8 mm J1 JIS head screw that is holding the trigger in place.
      Ask FixBot
    3. Thrustmaster T Flight Hotas 4 Trigger Replacement: step 4, image 1 of 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: step 4, image 2 of 3 Thrustmaster T Flight Hotas 4 Trigger Replacement: step 4, image 3 of 3
      • Remove trigger and metal spring.
      • Remember to position the metal spring in the exact same place.
      Ask FixBot
Aaron Banaga
556 Reputation
4 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 60
All Time: 4,404
