Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement
  1. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, J1 Screws on Throttle: step 1, image 1 of 1
    • Be sure to disconnect the controller from the power source before disassembling.
    • Remove the five 15 mm J1 JIS head screws from the front of the throttle.
    Ask FixBot
  2. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: step 2, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, Throttle Panel: step 2, image 2 of 2
    • Using your hands, pull away the panel from the throttle.
    Ask FixBot
  3. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: step 3, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement, R2 & L2 Buttons: step 3, image 2 of 2
    • Remove the two 7 mm J1 JIS head screws from the panel covering the buttons.
    Ask FixBot
  4. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 4, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 4, image 2 of 2
    • Pull the panel that is covering the R2 button away from the throttle.
    Ask FixBot
  5. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 5, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 5, image 2 of 2
    • Carefully push the R2 button from the outside of the panel.
    • Be cautious of the spring attached to the button as it can be easily lost.
    Ask FixBot
  6. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 6, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 6, image 2 of 2
    • Remove the two 4 mm J1 JIS head screws from the panel covering the L2 button.
    Ask FixBot
  7. Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 7, image 1 of 2 Thrustmaster T Flight Hotas 4 R2 & L2 Buttons Replacement: step 7, image 2 of 2
    • Carefully push the L2 button from the outside of the panel.
    Ask FixBot
2 other people completed this guide.
Crystal Nguyen
630 Reputation
4 Guides authored
CSU Fullerton, Team S2-G1, Bruce Fall 2017 Member of CSU Fullerton, Team S2-G1, Bruce Fall 2017
CSUF-BRUCE-F17S2G1
3 Members
23 Guides authored
1 Guide Comment
Hello, m R2 button is broken. Do you know where i can print a new one ?
louis_tiquet - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,969
