Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Parts
Tools
Introduction
Go to step 1 ↓A three-way switch is a common type of light switch that is used in many homes to control a single light fixture from two or more locations. Over time, these switches may become worn or damaged, requiring replacement.
Replacing a three-way switch may seem like a daunting task, but with the right tools and instructions, it can be a simple DIY project. In this guide, we will provide step-by-step instructions on how to replace a three-way switch safely and effectively.
Whether you are a seasoned DIYer or new to home repairs, this guide will give you the confidence and knowledge you need to replace a three-way switch and restore proper functionality to your lighting system.
While wearing insulated gloves, gently pull out the switch and use a Duspol or any other Voltmeter to test if there is voltage at the contacts.
2 other people completed this guide.
