Up to 20% off select tools
Thread a Sewing Machine
Views: 66K
View statistics:
Past 24 Hours:
12
Past 7 Days:
107
Past 30 Days:
537
All Time:
65,855
Comments: 1
1 guide comment.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 51
51 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Introduction
Go to step 1 ↓
You don’t need a sewing machine to sew. But a machine can save you a lot of time when you make repairs, so if you have access to a sewing machine, here’s how to thread it. In this guide we’re using a Bernina 830, but the process will be similar for most sewing machines. Refer to your sewing machine’s owner’s manual for specific directions on how to thread the machine.
Return to the Patagonia Care & Repair homepage.
    1. Thread a Sewing Machine, Thread a Sewing Machine: step 1, image 1 of 3 Thread a Sewing Machine, Thread a Sewing Machine: step 1, image 2 of 3 Thread a Sewing Machine, Thread a Sewing Machine: step 1, image 3 of 3
      • Place a spool on the pin. Pull the thread from the spool straight out, following the length of the machine.
      • Hook the thread under the eyelet on the outer edge of the machine.
      • With one hand, hold the spool steady. Using the eyelet as a pivot, pull the string perpendicular with the other hand. Lay the thread into the slot, which bisects the top of the machine.
      Ask FixBot
    2. Thread a Sewing Machine: step 2, image 1 of 3 Thread a Sewing Machine: step 2, image 2 of 3 Thread a Sewing Machine: step 2, image 3 of 3
      • Pull the thread all the way across the slot on the top of the sewing machine. Then, pull the thread down toward the presser foot.
      • There is a lever just above the presser foot. Hook the thread under the lever until it rests in the crux.
      • Pull the thread back up toward the top of the machine.
      Ask FixBot
    3. Thread a Sewing Machine: step 3, image 1 of 3 Thread a Sewing Machine: step 3, image 2 of 3 Thread a Sewing Machine: step 3, image 3 of 3
      • At the top of the machine, lead the thread along the groove of the take-up lever.
      • Once you've fed the thread into the crux of the take-up lever, pull the thread back down towards the presser foot.
      • If you've threaded correctly, your thread should form a complete zigzag—first down, then up, then back down all the way to the presser foot.
      Ask FixBot
    4. Thread a Sewing Machine: step 4, image 1 of 2 Thread a Sewing Machine: step 4, image 2 of 2
      • Hook the thread behind the small, bent arm where the needle attaches to the machine.
      • Guide the thread, from front to back, through the eye of the needle, leaving a loose end of approximately 10 cm.
      • If the end of your thread has frayed and you cannot guide it through the eye of the needle, snip off the frayed end and try again.
      Ask FixBot
    5. Thread a Sewing Machine: step 5, image 1 of 2 Thread a Sewing Machine: step 5, image 2 of 2
      • After you've guided the thread through the eye of the needle, pull the thread down and through the large groove in the presser foot.
      • Hook the thread along the groove and pull it perpendicular toward the body of the machine.
      Ask FixBot
    6. Thread a Sewing Machine: step 6, image 1 of 3 Thread a Sewing Machine: step 6, image 2 of 3 Thread a Sewing Machine: step 6, image 3 of 3
      • While continuing to hold the top thread advance the sewing machine with the balance wheel (also know as the hand wheel), to pick up the bobbin thread.
      • Only turn the balance wheel in the direction that advances the machine. Usually, this means turning the wheel towards you. Turning the wheel in the opposite direction can ruin the tension on the sewing machine, causing it to jam. See your sewing machine manual for instructions specific to your machine.
      • Grasp these two threads between pinched fingers and pull them in unison toward the body of the machine, leaving two to three inch tails.
      Ask FixBot
    7. Thread a Sewing Machine: step 7, image 1 of 2 Thread a Sewing Machine: step 7, image 2 of 2
      • Slide the sewing machine table onto the machine.
      • Hold the sewing machine table so that is lays flush with the sewing machine.
      Ask FixBot
    8. Thread a Sewing Machine: step 8, image 1 of 2 Thread a Sewing Machine: step 8, image 2 of 2
      • Lock the sewing machine table into place by pushing the clamp lever to the right until it engages.
      Ask FixBot
Finish Line
11 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
1 Guide Comment
How do u thread a sewmor model 202?
Helen jennings - Reply Share
Past 24 Hours: 12
Past 7 Days: 107
Past 30 Days: 537
All Time: 65,855
