This teardown is not a repair guide. To repair your Thomas Ride On Train, use our service manual.
  1. Thomas Ride on Train - System Diagram and Components, Thomas Ride on Train - System Diagram and Components: step 1, image 1 of 1
    • System Components
    • When power is applied to the charging connector it activates a relay which disconnects the power to the main circuits.
    • The main powerswitch is under the large yellow lever and simply applies power from the battery to the control board in the console.
    • A multipole switch is used to reverse the direction of the motor
    • An LED in the console flashes with the sound
    • The sound is provided by a loudspeaker in the base
    Ask FixBot
  2. Thomas Ride on Train - System Diagram and Components: step 2, image 1 of 2 Thomas Ride on Train - System Diagram and Components: step 2, image 2 of 2
    • Charging Connector
    • The charging connector is on the rear of the train between the buffers
    • My connector is a "old style" connector which is effectively a phono, the new style is a more conventional power connector
    Ask FixBot
  3. Thomas Ride on Train - System Diagram and Components: step 3, image 1 of 1
    • Power Switch and Charging Relay Board
    Ask FixBot
  4. Thomas Ride on Train - System Diagram and Components, 6v Sealed Lead Acid Battery: step 4, image 1 of 1
    • This battery has been replaced, the originals attach via a clip
    • Note the fuse on the positive connector
    Ask FixBot
  5. Thomas Ride on Train - System Diagram and Components, Reversing switch and LED: step 5, image 1 of 1
    • This switch is controlled by the level on the console and switches the polarity of the motor connectors.
    • Middle position is off, the other two positions are forward and backwards
    • If you are replacing the LED don't forget that the polarity of the wires is important
    Ask FixBot
  6. Thomas Ride on Train - System Diagram and Components, Control board: step 6, image 1 of 1
    • Has three switches to activate the music and connectors leading off to the motor, speaker, LED and battery
    Ask FixBot
  7. Thomas Ride on Train - System Diagram and Components, Loudspeaker: step 7, image 1 of 1
    • This is a 16ohm speaker
    Ask FixBot
  8. Thomas Ride on Train - System Diagram and Components, Motor: step 8, image 1 of 1
    • 6v electric motor with capacitor for noise and spark suppressor wired across the terminals
    Ask FixBot
Andy from Workshopshed
447 Reputation
3 Guides authored
10 Guide Comments
sound their but it's stoped moving
Leona - Reply Share
If you've got sound but no movement then the most likely cause is the battery is discharged or defective. If you have a multimeter you could check the voltage on the battery.
If may also be a motor / mechanical issue. With the power disconnected you should be able to rotate the wheels but it won't spin freely as there is a gearbox.
Andy from Workshopshed - Reply Share
Movement but no sound? Been charged
Shiipwreck Flynn - Reply Share
That could be a problem with the sound board which lives inside the steering wheel. It's quite a challenge to get to that which is what caused me to write the guide in the first place. I had to clean the switches on that board to get mine to work.
Alternatively could be a loose or broken wire on the speaker which is down in the base, one of the first things you get too when stripping it down.
What do I clean it with? Just polish? Had a look. Wires look fine so im confused lol
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 70
All Time: 8,980
