Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Community-Contributed Guide
Parts
Tools
Remove the display bezel. It is held on by 2-sided tape. Removal is easier if you apply gentle heat to soften the tape.
The bezel is taped in on all sides. Start from the sides and work your way around. Take care not to deform or bend the bezel.
The panel is held in with three strips of 10mm wide ~0,5-0,8mm thick strechy adhesive tape between the back of the panel and the magnesium case. Removal is difficult. Heating the case from the back can help. If the panel is already broken it is ok to force it out with a pry tool.
Pay attention not to damage the display cable located in the lower left corner of the panel.
Peel off the metal tape and pull the cable out towards the lower side of the panel. Do not lift upwards on the cable.
Remove the old tape from the back of the display mount.
Add 3 strips of new double-sided 10mm tape where the tape was removed.
Carefully press display into newly-taped display mount
4 other people completed this guide.
