Up to 20% off select tools
ThinkPad Yoga 12 SSD Replacement
Views: 6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
5,981
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Moderate
Community-Contributed Guide
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
Introduction
Go to step 1 ↓
Make sure you have a replacement ready! This will involve some drive formatting.
    1. ThinkPad Yoga 12 SSD Replacement, Screws: step 1, image 1 of 3 ThinkPad Yoga 12 SSD Replacement, Screws: step 1, image 2 of 3 ThinkPad Yoga 12 SSD Replacement, Screws: step 1, image 3 of 3
      • Remove the ten Phillips screws using a Philips 00 screwdriver
      Ask FixBot
    2. ThinkPad Yoga 12 SSD Replacement, Prying: step 2, image 1 of 2 ThinkPad Yoga 12 SSD Replacement, Prying: step 2, image 2 of 2
      • Pry up the case carefully using a spudger.
      • Make sure to not push the spudger in too far, as this could result in internal damage
      Ask FixBot
    3. ThinkPad Yoga 12 SSD Replacement, Lift off cover: step 3, image 1 of 1
      • Lift off the cover, and you're done!
      Ask FixBot
    1. ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: step 4, image 1 of 2 ThinkPad Yoga 12 SSD Replacement, Remove SSD from the laptop: step 4, image 2 of 2
      • Carefully remove two Phillips screws with a Phillips 0 screwdriver
      • Static sensitive components!
      Ask FixBot
    2. ThinkPad Yoga 12 SSD Replacement: step 5, image 1 of 2 ThinkPad Yoga 12 SSD Replacement: step 5, image 2 of 2
      • Gently grab the plastic tab. Lift and pull the SSD assembly out of the computer
      Ask FixBot
    3. ThinkPad Yoga 12 SSD Replacement, Remove enclosure: step 6, image 1 of 2 ThinkPad Yoga 12 SSD Replacement, Remove enclosure: step 6, image 2 of 2
      • Remove the 4 identical Phillips screws with a Phillips 00 screw driver (they are on both sides).
      Ask FixBot
    4. ThinkPad Yoga 12 SSD Replacement, Done!: step 7, image 1 of 2 ThinkPad Yoga 12 SSD Replacement, Done!: step 7, image 2 of 2
      • Carefully remove the SSD enclosure.
      • Note: The SSD enclosure is made of thin metal. It can be easily deformed. Be careful when removing from the SSD.
      Ask FixBot
6 other people completed this guide.
Author
with
[deleted]
1,338 Reputation
3 Guides authored
1 Guide Comment
Almost perfect instructions. I do recommend removing the active pen first. Also it's a good idea to remind people that the active pen holder is screwed to the case cover from the inside and will come out as part of the cover.
Dani Deitch - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 5,981
