Up to 20% off select tools
ThinkPad Yoga 12 Battery Replacement
Views: 7.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
98
All Time:
7,887
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 6 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
Now your computer battery power will finally last over 1 hour!
    1. ThinkPad Yoga 12 Battery Replacement, Screws: step 1, image 1 of 3 ThinkPad Yoga 12 Battery Replacement, Screws: step 1, image 2 of 3 ThinkPad Yoga 12 Battery Replacement, Screws: step 1, image 3 of 3
      • Remove the ten Phillips screws using a Philips 00 screwdriver
      Ask FixBot
    2. ThinkPad Yoga 12 Battery Replacement, Prying: step 2, image 1 of 2 ThinkPad Yoga 12 Battery Replacement, Prying: step 2, image 2 of 2
      • Pry up the case carefully using a spudger.
      • Make sure to not push the spudger in too far, as this could result in internal damage
      Ask FixBot
    3. ThinkPad Yoga 12 Battery Replacement, Lift off cover: step 3, image 1 of 1
      • Lift off the cover, and you're done!
      Ask FixBot
    1. ThinkPad Yoga 12 Battery Replacement, Removing the screw: step 4, image 1 of 2 ThinkPad Yoga 12 Battery Replacement, Removing the screw: step 4, image 2 of 2
      • Remove the one and only Phillips screw with a Phillips 0 screwdriver.
      Ask FixBot
    2. ThinkPad Yoga 12 Battery Replacement, Lift: step 5, image 1 of 2 ThinkPad Yoga 12 Battery Replacement, Lift: step 5, image 2 of 2
      • Carefully lift the battery. There is a small bit of adhesive underneath the green.
      • Make sure to not bend the battery! This can result in a violent explosion with flames and shrapnel!
      Ask FixBot
    3. ThinkPad Yoga 12 Battery Replacement, Connecter: step 6, image 1 of 3 ThinkPad Yoga 12 Battery Replacement, Connecter: step 6, image 2 of 3 ThinkPad Yoga 12 Battery Replacement, Connecter: step 6, image 3 of 3
      • Carefully pull the connector out from underneath the logic board to remove the battery.
      Ask FixBot
9 other people completed this guide.
Author
with
[deleted]
1,338 Reputation
3 Guides authored
1 Guide Comment
These directions (and those for replacing the SSD) were very helpful. Everything worked well for about a week after which time the battery started having charging problems (again). The computer will start to charge, get to ~25% at which point the machine reports that it’s charging, but doesn’t get beyond ~25%. “Troubleshooting” in Win 10 doesn’t reveal any troubles to shoot. I am now trying to figure out whether the problem is with the new (supposedly Lenovo-brand) battery or perhaps the power cord. Any suggestions?
ellamama - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 98
All Time: 7,887
