ThinkPad X1 Carbon Wireless Card Replacement
    1. ThinkPad X1 Carbon Wireless Card Replacement, Loosen Cover Screws: step 1, image 1 of 1
      • Using the #0 Phillips screwdriver, loosen the seven cover screws. they will not come all of the way out.
      Ask FixBot
    2. ThinkPad X1 Carbon Wireless Card Replacement: step 2, image 1 of 1
      • Using the spudger pop the cover loose and remove.
      Ask FixBot
    3. ThinkPad X1 Carbon Wireless Card Replacement, Disconnect Battery: step 3, image 1 of 1
      • Use only plastic tools to disconnect battery cable
      • Slide battery connector in the direction if the arrow to disconnect.
      • You can leave the battery or remove it using the red circles for the screw locations.
      Ask FixBot
    4. ThinkPad X1 Carbon Wireless Card Replacement: step 4, image 1 of 1
      • Remove screw holding the wireless card in place.
      Ask FixBot
    5. ThinkPad X1 Carbon Wireless Card Replacement, Remove Antenna Cables: step 5, image 1 of 1
      • Carefully remove the antenna cables and slide out the card in the direction of the arrow.
      • The gray connector is on the top. The black connector is closer to the battery.
      Ask FixBot
3 other people completed this guide.
Mike
2,002 Reputation
5 Guides authored
iReconstruction Member of iReconstruction
Business
1 Member
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 119
All Time: 7,211
