ThinkPad X1 Carbon Fan Replacement
    1. ThinkPad X1 Carbon Fan Replacement, Loosen Cover Screws: step 1, image 1 of 1
      • Loosen the seven cover screws. They will not come out.
      Ask FixBot
    2. ThinkPad X1 Carbon Fan Replacement, Remove Cover: step 2, image 1 of 1
      • Use a spudger to pop loose the cover and slide it off.
      Ask FixBot
    3. ThinkPad X1 Carbon Fan Replacement, Disconnect Battery: step 3, image 1 of 1
      • Only use plastic to remove battery connector
      • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
      • Remove four screws holding battery in place and remove battery.
      Ask FixBot
      • The 4 perimeter screws also hold the tow audio speakers in place. And there is a 5th screw dead center of the battery. The battery cable is not easy to remove, nor is it easy to re-connect.
      Ask FixBot
    4. ThinkPad X1 Carbon Fan Replacement, Disconnect Fan Cable: step 5, image 1 of 1
      • Use your spudger to open the connector in the direction of the arrow. Carefully remove the ribbon cable
      • These connectors are very delicate. Use care when removing cables.
      Ask FixBot
    5. ThinkPad X1 Carbon Fan Replacement, Remove Fan: step 6, image 1 of 1
      • Loosen screws and pull fan up and out of the case.
      • Be sure to apply heat sink paste when putting fan back on CPU
      Ask FixBot
10 other people completed this guide.
Mike
2,002 Reputation
5 Guides authored
iReconstruction Member of iReconstruction
Business
1 Member
60 Guides authored
1 Guide Comment
Great guide. I do recommend ordering the recommended tools, especially the spudger. There isn’t a lot of room to get the battery cable disconnected, so some of my other spudgers weren’t sturdy enough or wouldn’t have fit. My computer is working again and I didn’t have to pay a king’s ransom and wait 3 weeks (hey, I’m in Montana! I’m lucky to find anyone to fix a computer). Thanks!
marceec - Reply Share
Past 24 Hours: 5
Past 7 Days: 40
Past 30 Days: 201
All Time: 16,436
