ThinkPad X1 Carbon Battery Replacement
    1. ThinkPad X1 Carbon Battery Replacement, Loosen Cover Screws: step 1, image 1 of 1
      • Loosen the seven cover screws. They will not come out.
      Ask FixBot
    2. ThinkPad X1 Carbon Battery Replacement, Remove Cover: step 2, image 1 of 1
      • Use spudger to pop loose cover and slide off.
      Ask FixBot
    3. ThinkPad X1 Carbon Battery Replacement, Disconnect Battery: step 3, image 1 of 1
      • Only use plastic to remove battery connector
      • Gently remove battery connector by pushing with the spudger in the direction of the arrow.
      • Remove five screws holding battery in place and remove battery.
      Ask FixBot
11 other people completed this guide.
Mike
2,002 Reputation
5 Guides authored
iReconstruction Member of iReconstruction
Business
1 Member
60 Guides authored
3 Guide Comments
bonjour,
depuis que j’ai changé la batterie, elle ne charge plus… j’ai remis celle d’origine, idem…
Une idée?
merci d’avance.
Franck D'ALOIA - Reply Share
Bonjour,
J’ai le même phénomène que celui décrit plus haut par Franck D’ALOIA. La batterie de remplacement indique 100% de charge mais ne tient que 10min tout au plus.
Une idée ??
Merci à vous
Lamine Bouras - Reply Share
Minor correction to step #3 - the text says "remove 4 screws", but reality - and the photo - is that there are five screws.
Important: Note that the center one in the circular hole in the battery (under the trackpad) is a shorter length than the others.
davidhollway - Reply Share
Past 24 Hours: 20
Past 7 Days: 104
Past 30 Days: 393
All Time: 28,233
