Up to 20% off select tools
ThinkPad T420 Keyboard Replacement
Views: 17K
View statistics:
Past 24 Hours:
12
Past 7 Days:
68
Past 30 Days:
285
All Time:
17,181
Comments: 5
2 comments on steps, 3 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
If your Lenovo T420 has keyboard or thermal issues, this guide will show you how to replace the keyboard and gain partial fan access.
Guide notes
  • If you are removing the keyboard for fan access, being too close or using too much air can damage the fan. If the damage is particularly severe the system will give you a fan error and shut off to protect the processor (and dGPU, if equipped). If the system says Fan error when it is rebooted, the fan is damaged and will need to be replaced in order for the system to boot. Use caution if you suspect the fan is failing prior to cleaning the heatsink. The fan in the author's system was rattling before cleaning and it has not happened since. If the fan ends up getting damaged, this is NOT your fault; all you did was reveal a hidden failure.
  • If you are replacing the keyboard, check the Lenovo HMM to determine what keyboard you need. This can also be found on the back of your old keyboard as well. I am not referencing a part because every country uses a different FRU.
  • While this is not a hard repair, you may wish to sort your screws. Multiple screw types are used.
  • Watch the ground on the chassis by the RAM door, especially if it has been serviced before. This can get in the way or come loose from the chassis. If this happens push it back into place. It will eventually come out again, so the only cure is to replace the lower chassis.
    1. ThinkPad T420 Keyboard Replacement, Change note: step 1, image 1 of 2 ThinkPad T420 Keyboard Replacement, Change note: step 1, image 2 of 2
      Tool used on this step:
      Essential Electronics Toolkit
      $25.46
      Buy
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Ask FixBot
    1. ThinkPad T420 Keyboard Replacement, Keyboard FRU: step 2, image 1 of 1
      • If the label on the back of the keyboard is not worn, that can be used to reference which keyboard is needed.
      • IMPORTANT: Each country has a different keyboard FRU part number. To match the keyboard you have and which one you need to purchase, check the back label or refer to the Lenovo HMM.
      Ask FixBot
    1. ThinkPad T420 Keyboard Replacement, Unlock the battery: step 3, image 1 of 3 ThinkPad T420 Keyboard Replacement, Unlock the battery: step 3, image 2 of 3 ThinkPad T420 Keyboard Replacement, Unlock the battery: step 3, image 3 of 3
      • If completing a step like a clone of your old hard drive/SSD, DO NOT remove the battery until the process is complete!
      • Unlock the latch locking the battery in the laptop.
      • NOTE: To remove the battery, the tab must be held in to avoid having the lock reinitiate inside the laptop.
      Ask FixBot
    2. ThinkPad T420 Keyboard Replacement, Release the battery: step 4, image 1 of 3 ThinkPad T420 Keyboard Replacement, Release the battery: step 4, image 2 of 3 ThinkPad T420 Keyboard Replacement, Release the battery: step 4, image 3 of 3
      • After unlocking the battery, remove the battery from the reverse way it is installed to remove it from the laptop.
      Ask FixBot
    1. ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 5, image 1 of 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 5, image 2 of 3 ThinkPad T420 Keyboard Replacement, Remove the RAM door: step 5, image 3 of 3
      • EET owners: Your kit has this bit. No purchase needed.
      • If you are removing this cover to upgrade/replace your lower RAM module, the keyboard screw DOES NOT need to be removed.
      • WWAN ready systems ship with antenna covers over these cables. Someone installed a WLAN card in this T420 which disabled the better card and was removed.
      • Loosen the screw in red (Phillips #2). This screw stays captive in the bottom RAM door cover, and does not need to be removed.
      • Pull the cover up with a fingernail or a nonmarring pry tool.
      • Remove the screw retaining the keyboard.
      Ask FixBot
    2. ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 6, image 1 of 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 6, image 2 of 3 ThinkPad T420 Keyboard Replacement, Remove the keyboard: step 6, image 3 of 3
      • Open the laptop.
      • To remove the keyboard, release the keyboard hooks using a plastic pry tool.
      • Once the keyboard is loose, remove it from the chassis.
      Ask FixBot
    3. ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 7, image 1 of 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 7, image 2 of 3 ThinkPad T420 Keyboard Replacement, Disconnect the keyboard: step 7, image 3 of 3
      • To reinstall the keyboard, refer to the steps in this guide.
      • This step can be skipped if you remove the keyboard to upgrade/replace the RAM. However, disconnecting it may allow for better access to the upper (Keyboard) RAM module.
      • If you have a can of compressed air available, some of the dust can be removed at this point. Further disassembly is required for a full cleaning.
      • Disconnect the keyboard from the motherboard. Use a plastic pry tool for this step.
      Ask FixBot
Finish Line
10 other people completed this guide.
Author
with
Nick
107,133 Reputation
73 Guides authored
3 Guide Comments
Excellent guide, I like the detail specifying screw bits
Jakezxz1 - Reply Share
replacing the key went good but can’t get in because of password. need help
Steve Jacofsky - Reply Share
I love how simply disassemby are in those old ThinkPads <3
Ziobro - Reply Share
Past 24 Hours: 12
Past 7 Days: 68
Past 30 Days: 285
All Time: 17,181
