Tools
Introduction
Go to step 1 ↓Nearly any 2.5 inch SATA hard drive or solid state drive will work as a replacement or upgrade to the factory hard drive.
There are two two locks for the battery, one on the left and one on the right.
Slide the left lock to the left.
Unscrew the 5 screws holding the back on. These screws will unscrew from the laptop, but will remain secured to the back plate even when fully loosened. Once unscrewed, the plate can be removed.
The hard drive is on the bottom left side of the exposed laptop.
Remove the 3.5mm long M3 screw securing the hard drive to the laptop.
