Up to 20% off select tools
ThinkPad 13 Chromebook Display Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
66
All Time:
2,398
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a broken LCD in your ThinkPad 13 Chromebook, or upgrade the HD display to a FHD display on an entry-level model.
    1. ThinkPad 13 Chromebook Display Replacement, Lower Case: step 1, image 1 of 2 ThinkPad 13 Chromebook Display Replacement, Lower Case: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Before proceeding, unplug and power down your ThinkPad. Close the display and lay it on a soft surface, top-side down.
      • Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
      • You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
      Ask FixBot
    2. ThinkPad 13 Chromebook Display Replacement: step 2, image 1 of 1
      • Insert an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the case, pushing inward to release the clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    3. ThinkPad 13 Chromebook Display Replacement: step 3, image 1 of 1
      • When all the clips have been released, you should be able to easily remove the lower case.
      • If you feel resistance when lifting the case, ensure all the clips have been released and all the screws are adequately loosened.
      Ask FixBot
    4. ThinkPad 13 Chromebook Display Replacement, Battery Connector: step 4, image 1 of 1
      • Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
      Ask FixBot
    5. ThinkPad 13 Chromebook Display Replacement, Battery Screws: step 5, image 1 of 1
      • Remove the four screws securing the battery to the upper case.
      Ask FixBot
    6. ThinkPad 13 Chromebook Display Replacement: step 6, image 1 of 1
      • Lift the battery out of the upper case.
      Ask FixBot
    1. ThinkPad 13 Chromebook Display Replacement, Display Removal: step 7, image 1 of 2 ThinkPad 13 Chromebook Display Replacement, Display Removal: step 7, image 2 of 2
      • Before proceeding, unplug and power down your ThinkPad. Set your computer to face you, with the screen open.
      • Use the plastic opening tool to pull the panel forward and release it from the display assembly.
      • You may need a little help from your fingers for the thicker bottom bezel.
      • Be careful not to put pressure on the LCD itself, as it could damage the display.
      Ask FixBot
    2. ThinkPad 13 Chromebook Display Replacement: step 8, image 1 of 1
      • Open the laptop completely to 180 degrees and lay it flat.
      • Remove the four screws that secure the LCD panel to the plastic. Do not confuse these for the screws securing the hinge to the display assembly.
      Ask FixBot
    3. ThinkPad 13 Chromebook Display Replacement: step 9, image 1 of 2 ThinkPad 13 Chromebook Display Replacement: step 9, image 2 of 2
      • Carefully separate the LCD panel from the plastic cover. and lower the screen onto the keys.
      Ask FixBot
    4. ThinkPad 13 Chromebook Display Replacement: step 10, image 1 of 2 ThinkPad 13 Chromebook Display Replacement: step 10, image 2 of 2
      • Peel off the sticker securing the display cable to the LCD panel.
      • Using the flat end of a spudger, lift the cable lock and gently remove the display cable from the LCD panel.
      • Be very gentle removing this cable, as it is quite delicate.
      Ask FixBot
    5. ThinkPad 13 Chromebook Display Replacement: step 11, image 1 of 1
      • Remove the LCD panel.
      Ask FixBot
2 other people completed this guide.
Author
with
Whitson Gordon
586 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 66
All Time: 2,398
