ThinkPad 13 Chromebook Battery Replacement
    1. ThinkPad 13 Chromebook Battery Replacement, Lower Case: step 1, image 1 of 2 ThinkPad 13 Chromebook Battery Replacement, Lower Case: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Before proceeding, unplug and power down your ThinkPad. Close the display and lay it on a soft surface, top-side down.
      • Use a Size 0 Philips screwdriver to loosen the nine screws on the bottom of the case. They will not come out entirely, but you will feel when they are loose enough.
      • You will need to remove the rubber pads from the bottom three screws using a pair of tweezers.
      Ask FixBot
    2. ThinkPad 13 Chromebook Battery Replacement: step 2, image 1 of 1
      • Insert an opening pick into the space between the lower case and the chassis.
      • Slide the opening pick around the case, pushing inward to release the clips securing the lower case. You should feel and hear the clip pop free.
      Ask FixBot
    3. ThinkPad 13 Chromebook Battery Replacement: step 3, image 1 of 1
      • When all the clips have been released, you should be able to easily remove the lower case.
      • If you feel resistance when lifting the case, ensure all the clips have been released and all the screws are adequately loosened.
      Ask FixBot
    4. ThinkPad 13 Chromebook Battery Replacement, Battery Connector: step 4, image 1 of 1
      • Use a spudger or other plastic tool to push the battery connector in the direction of the arrow, removing it from its socket.
      Ask FixBot
    5. ThinkPad 13 Chromebook Battery Replacement, Battery Screws: step 5, image 1 of 1
      • Remove the four screws securing the battery to the upper case.
      Ask FixBot
    6. ThinkPad 13 Chromebook Battery Replacement: step 6, image 1 of 1
      • Lift the battery out of the upper case.
      Ask FixBot
Whitson Gordon
586 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 68
All Time: 3,048
