The Sharper Image Literati Tablet SD Port Replacement
  1. The Sharper Image Literati Tablet SD Port Replacement, Battery: step 1, image 1 of 1
    • Wedge plastic spudger tool between the back panel and the body of device.
    • Pry apart the back panel and the device.
    Ask FixBot
  2. The Sharper Image Literati Tablet SD Port Replacement: step 2, image 1 of 1
    • Desolder the battery wires from the circuit board.
    Ask FixBot
  3. The Sharper Image Literati Tablet SD Port Replacement: step 3, image 1 of 1
    • Warm the battery with a hair dryer.
    • Be carful not to over-heat the battery, this could cause the battery to ignite.
    Ask FixBot
  4. The Sharper Image Literati Tablet SD Port Replacement: step 4, image 1 of 1
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Gently wedge a spudger or thin plastic card between the battery and the body of device. Work the spudger or card along the length of the battery to free it from the adhesive.
    • Do not bend or puncture the battery. Work slowly and carefully.
    Ask FixBot
  5. The Sharper Image Literati Tablet SD Port Replacement, SD Port: step 5, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the fifteen 4mm screws from the silver peripheral edging.
    Ask FixBot
  6. The Sharper Image Literati Tablet SD Port Replacement: step 6, image 1 of 1
    • Use a Phillips #00 screwdriver to remove three 4 mm screws from the circuit board containing the headphone jack and power jack.
    Ask FixBot
  7. The Sharper Image Literati Tablet SD Port Replacement: step 7, image 1 of 1
    • Remove the circuit board.
    Ask FixBot
  8. The Sharper Image Literati Tablet SD Port Replacement: step 8, image 1 of 1
    • Unclip ZIF clip from the chip and unplug ribbon cable.
    Ask FixBot
  9. The Sharper Image Literati Tablet SD Port Replacement: step 9, image 1 of 1
    • Detach the peripheral edge with plastic wedge.
    • This may require a little hard pulling.
    Ask FixBot
  10. The Sharper Image Literati Tablet SD Port Replacement: step 10, image 1 of 1
    • Remove peripheral silver edge.
    Ask FixBot
  11. The Sharper Image Literati Tablet SD Port Replacement: step 11, image 1 of 1
    • Remove screws from the large metal shielding.
    Ask FixBot
  12. The Sharper Image Literati Tablet SD Port Replacement: step 12, image 1 of 1
    • Remove the silver backing plate and the adhered SD port chip.
    Ask FixBot
Spencer Dodder
560 Reputation
4 Guides authored
IUPUI, Team S5-G4, Baechle Spring 2018 Member of IUPUI, Team S5-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G4
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 44
All Time: 482
