Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Introduction
Go to step 1 ↓In certain cases the device will stop playing music or begin to play distorted music. If this is the case with your claw device, you probably need to open the bottom of the device and clean off the speaker or clean out the sound port on the bottom cover. This guide will assist you in taking the proper measure to do so.
Tools
Once you have removed the bottom cover you should have clear access to the music player.
Locate the music player and check to see if it is visibly dirty or clogged.
Using the straw that comes with your air duster, aim the duster in a way that the air will push the dust away from the music player.
