Up to 20% off select tools
The Claw Case Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
38
Past 30 Days:
115
All Time:
2,472
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
If the clear plastic case on your claw device is broken or damaged, it can easily be replaced. This required the opening of the top cover of your claw device in order to access the clear plastic panels. Using this easy to follow replacement guide will make case replacement an easy task.
    1. The Claw Case Replacement, Top Cover: step 1, image 1 of 1
      • Place The Claw machine in the up-right position with the control knobs facing you.
      Ask FixBot
    2. The Claw Case Replacement: step 2, image 1 of 1
      • Turn The Claw machine upside-down placing the top cover on the surface of your work area.
      Ask FixBot
    3. The Claw Case Replacement: step 3, image 1 of 1
      • Remove all ten 6mm phillips #1 screws underneath the top cover using your #1 phillips head screwdriver.
      • It is helpful to choose a clear, well lit work space. There are multiple tiny screws that are easy to lose.
      Ask FixBot
    4. The Claw Case Replacement: step 4, image 1 of 1
      • Turn The Claw machine back to the upright position with controls facing you.
      Ask FixBot
    5. The Claw Case Replacement: step 5, image 1 of 1
      • Remove the top cover of The Claw machine.
      Ask FixBot
    6. The Claw Case Replacement: step 6, image 1 of 2 The Claw Case Replacement: step 6, image 2 of 2
      • Remove the ten 6 mm phillips #1 screws from the top flange.
      Ask FixBot
    7. The Claw Case Replacement: step 7, image 1 of 1
      • Lift the flange upward and off to the side of the machine.
      • There is enough wire connecting the flange to the machine that you will not need to cut the wire. The flange can be moved off to the side of the machine while you are working.
      • Cutting or ripping out the wire will cause damage to the machine so try not to put much tension on the wire.
      Ask FixBot
    1. The Claw Case Replacement, Case: step 8, image 1 of 1
      • The glass you intend to replace will have four 6mm #1 phillips head screws on either side located in the silver corner pieces.
      Ask FixBot
    2. The Claw Case Replacement: step 9, image 1 of 1
      • Loosen all eight screws using your phillips head #1 screwdriver so that the glass can be removed.
      Ask FixBot
    3. The Claw Case Replacement: step 10, image 1 of 1
      • Gently remove the broken clear plastic case.
      • Remember how the case sat into the frame so that you can seat the new case in the same way.
      Ask FixBot
2 other people completed this guide.
Author
with
Alain Pierre
1,188 Reputation
9 Guides authored
1 Guide Comment
where can i get the clear plastic panels
cristian2002 - Reply Share
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 115
All Time: 2,472
