Up to 20% off select tools
The Claw Battery Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
138
All Time:
4,730
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to properly replace the batteries in your Claw Machine. If you are experiencing any power related issues with your device follows these steps.
    1. The Claw Battery Replacement, Batteries: step 1, image 1 of 1
      • Hold The Claw machine upright so that the controls are facing you.
      Ask FixBot
    2. The Claw Battery Replacement: step 2, image 1 of 1
      • Turn the device upside down keeping the controls facing in your direction.
      Ask FixBot
    3. The Claw Battery Replacement: step 3, image 1 of 1
      • Locate the battery compartment door on the bottom cover of The Claw.
      • Loosen the screw from the battery compartment door with your phillips head screwdriver.
      Ask FixBot
    4. The Claw Battery Replacement: step 4, image 1 of 1
      • Open the door and insert the 3 D-cell batteries using the correct configuration that is labeled on the inside of the compartment.
      • If the batteries are not placed in the right configuration the device will not operate. make sure to identify positive and negative sides of the battery and follow the configuration on the device.
      Ask FixBot
Author
with
Alain Pierre
1,188 Reputation
9 Guides authored
1 Guide Comment
daiobn ht45o9iyjugggjvj nvj vnv jnkrfdoelcbigvfcofrbbvfgb4vg3rcf2edebb
Jennifer Mateo - Reply Share
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 138
All Time: 4,730
