Up to 20% off select tools
Texas Instruments TI-92 Display Replacement
Views: 10K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
128
All Time:
10,266
Comments: 8
8 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
In this guide we will show how to remove the display to replace it if broken.
  • incomplete we currently do not know how to do this and can find no information on it
    1. Texas Instruments TI-92 Display Replacement, Back Cover: step 1, image 1 of 3 Texas Instruments TI-92 Display Replacement, Back Cover: step 1, image 2 of 3 Texas Instruments TI-92 Display Replacement, Back Cover: step 1, image 3 of 3
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      Ask FixBot
    2. Texas Instruments TI-92 Display Replacement: step 2, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 2, image 2 of 2
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      Ask FixBot
    3. Texas Instruments TI-92 Display Replacement: step 3, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 3, image 2 of 2
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      Ask FixBot
    1. Texas Instruments TI-92 Display Replacement, Batteries: step 4, image 1 of 3 Texas Instruments TI-92 Display Replacement, Batteries: step 4, image 2 of 3 Texas Instruments TI-92 Display Replacement, Batteries: step 4, image 3 of 3
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      Ask FixBot
    1. Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: step 5, image 1 of 3 Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: step 5, image 2 of 3 Texas Instruments TI-92 Display Replacement, Texas Instruments TI-92 Back Case Disassembly: step 5, image 3 of 3
      • Using a Philips Screwdriver #00 unscrew the twelve 11.8mm screws shown in the picture and located on the back of the calculator.
      Ask FixBot
    2. Texas Instruments TI-92 Display Replacement: step 6, image 1 of 1
      • Unscrew the 19mm screw located near center of the back of the calculator.
      • Remove the panel being held by the screw.
      Ask FixBot
    3. Texas Instruments TI-92 Display Replacement: step 7, image 1 of 1
      • Using the same Phillips screwdriver, unscrew the remaining three 11.8mm screws.
      Ask FixBot
    4. Texas Instruments TI-92 Display Replacement: step 8, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 8, image 2 of 2
      • Using the Ipod Opening Tool pull up on both sides of the rectangular module while keeping the rest of the calculator flat on a surface face down
      • You may get a lot of resistance from the module. Do not use too much force as you risk damage. Use small amounts of force to work the module out.
      Ask FixBot
    5. Texas Instruments TI-92 Display Replacement: step 9, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 9, image 2 of 2
      • Pull out the rectangular module when it is finally loose enough.
      Ask FixBot
    6. Texas Instruments TI-92 Display Replacement: step 10, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 10, image 2 of 2
      • Now pull up on the back cover of the calculator while holding the rest of it flat on a surface.
      • Be careful not to tilt the front of the calculator at this point. The keyboard buttons are now unsupported and will fall out of place.
      Ask FixBot
    1. Texas Instruments TI-92 Display Replacement, Motherboard: step 11, image 1 of 3 Texas Instruments TI-92 Display Replacement, Motherboard: step 11, image 2 of 3 Texas Instruments TI-92 Display Replacement, Motherboard: step 11, image 3 of 3
      • Pull the motherboard up while holding the rest of the calculator firmly in place
      • The motherboard has now separated from the rest of the calculator
      Ask FixBot
    1. Texas Instruments TI-92 Display Replacement, Display: step 12, image 1 of 1
      • Place the motherboard flat on a surface with the LCD screen facing down.
      • Using a #00 Philip Screwdriver remove the screw located on the left side of a spring-like object located near the center of the motherboard.
      Ask FixBot
    2. Texas Instruments TI-92 Display Replacement: step 13, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 13, image 2 of 2
      • Lift up on the material covering the motherboard starting from the upper right corner. Peel foil back only about half way down.
      • Make sure to slowly lift up on the plastic of the covering material and not the foil or the foil will rip.
      Ask FixBot
    3. Texas Instruments TI-92 Display Replacement: step 14, image 1 of 2 Texas Instruments TI-92 Display Replacement: step 14, image 2 of 2
      • Now slowly lift up the black tape located at the top of the calculator.
      • You will need to replace tape if removed so if you do not have this replacement part do not attempt to remove it
      Ask FixBot
    4. Texas Instruments TI-92 Display Replacement: step 15, image 1 of 3 Texas Instruments TI-92 Display Replacement: step 15, image 2 of 3 Texas Instruments TI-92 Display Replacement: step 15, image 3 of 3
      • Tilt the calculator up from the front so that you can see the LCD screen
      • Finish removing the black tape on this side of the motherboard.
      Ask FixBot
    5. Texas Instruments TI-92 Display Replacement: step 16, image 1 of 1
      • Do not know next step
      Ask FixBot
2 other people completed this guide.
Author
with
Daniel Maldonado
264 Reputation
9 Guides authored
Cal Poly, Team 15-51, Garner Spring 2010 Member of Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 128
All Time: 10,266
