Texas Instruments TI-92 Batteries Replacement
    1. Texas Instruments TI-92 Batteries Replacement, Back Cover: step 1, image 1 of 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: step 1, image 2 of 3 Texas Instruments TI-92 Batteries Replacement, Back Cover: step 1, image 3 of 3
      • The first step to any repair operation is to remove the front cover.
      • Grab the back of the calculator with one hand and the cover with the other.
      • Pull the cover off from one of the sides for easy removal.
      Ask FixBot
    2. Texas Instruments TI-92 Batteries Replacement: step 2, image 1 of 2 Texas Instruments TI-92 Batteries Replacement: step 2, image 2 of 2
      • Orientate the calculator with the top facing towards you.
      • Slide the locking tab,found on the top part of the calculator, to the unlock position.
      Ask FixBot
    3. Texas Instruments TI-92 Batteries Replacement: step 3, image 1 of 2 Texas Instruments TI-92 Batteries Replacement: step 3, image 2 of 2
      • "Locking Tab"
      • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
      • Then with the front of the calculator facing down, pull up on the back cover.
      • The calculator should now be orientated with the front facing down, as shown in picture 2.
      Ask FixBot
    1. Texas Instruments TI-92 Batteries Replacement, Batteries: step 4, image 1 of 3 Texas Instruments TI-92 Batteries Replacement, Batteries: step 4, image 2 of 3 Texas Instruments TI-92 Batteries Replacement, Batteries: step 4, image 3 of 3
      • The Batteries are now exposed and the calculator is face down with the back towards you.
      • Remove the bottom batteries by pressing the battery towards you while pulling it out from the far end.
      • If you can not do the previous step with your finger try using a flat ended tool such as an Ipod opening tool.
      • After the bottom battery has been removed push or slide the other(top) battery towards you until it is fully exposed in the battery slot.
      • Now simply remove the battery.
      Ask FixBot
4 other people completed this guide.
Daniel Maldonado
264 Reputation
9 Guides authored
Cal Poly, Team 15-51, Garner Spring 2010 Member of Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 46
All Time: 8,159
