Texas Instruments TI-83 Plus Individual Keys Replacement
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: step 1, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Backup Battery: step 1, image 2 of 2
      • Remove the battery cover.
      • Remove the AAA batteries from the calculator.
      Ask FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: step 2, image 1 of 1
      • Remove the 5mm Philips #00 screw holding backup battery cover.
      • Remove the backup battery cover.
      Ask FixBot
    3. Texas Instruments TI-83 Plus Individual Keys Replacement: step 3, image 1 of 1
      • Use plastic opening tool to remove the backup battery. Place the tool in the small cut-out next to the battery and pry the battery out.
      • Be careful, the backup battery is spring loaded and may shoot up when you remove it.
      Ask FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Back Case: step 4, image 1 of 1
      • Unscrew the six 7.5mm T6 screws on the back case. You will need to use a screwdriver with a long and skinny head.
      Ask FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: step 5, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement: step 5, image 2 of 2
      • Pry back case off. Insert the plastic opening tool in the track for the protective cover and pry the halves of the case apart.
      Ask FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: step 6, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Motherboard & Screen: step 6, image 2 of 2
      • Keep the screen face-down during this step. Only the motherboard is attached to the face-plate and the screen may fall out.
      • Remove the eight (8) 5mm Philips #00 screws on the motherboard.
      Ask FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: step 7, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement: step 7, image 2 of 2
      • Carefully remove the motherboard and screen. Grab the board by its side with one hand and the screen with the other. Carefully lift the two parts up.
      • Keep the face-plate face-down to prevent the keys from falling out.
      Ask FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: step 8, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Keyboard Mat: step 8, image 2 of 2
      • Remove light gray rubber keyboard mat.
      • Keep your calculator face down to ensure the individual keys do not fall out.
      Ask FixBot
    2. Texas Instruments TI-83 Plus Individual Keys Replacement: step 9, image 1 of 1
      • Clean the contacts on the keyboard with a soft cloth.
      Ask FixBot
    1. Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: step 10, image 1 of 2 Texas Instruments TI-83 Plus Individual Keys Replacement, Individual Keys: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to remove one key at a time.
      • Be sure to keep them organized if you are taking out multiple keys.
      Ask FixBot
2 other people completed this guide.
Jared
156 Reputation
2 Guides authored
Cal Poly, Team 18-37, Regan Fall 2012 Member of Cal Poly, Team 18-37, Regan Fall 2012
CPSU-REGAN-F12S18G37
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 42
All Time: 5,511
