Up to 20% off select tools
Texas Instruments TI-5130 Printer Unit Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
20
Past 30 Days:
100
All Time:
3,347
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Follow this guide to remove and replace the printing unit in the TI-5130 electronic calculator.
    1. Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: step 1, image 1 of 2 Texas Instruments TI-5130 Printer Unit  Replacement, Printer Unit: step 1, image 2 of 2
      • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
      Ask FixBot
    2. Texas Instruments TI-5130 Printer Unit  Replacement: step 2, image 1 of 1
      • Flip the calculator back over and remove the top cover.
      Ask FixBot
    3. Texas Instruments TI-5130 Printer Unit  Replacement: step 3, image 1 of 1
      • Disconnect the printing unit from the motherboard by pulling up on the connector – located in the bottom left of the motherboard.
      Ask FixBot
    4. Texas Instruments TI-5130 Printer Unit  Replacement: step 4, image 1 of 1
      • Remove the ink cartridge by pushing the tab back then lifting it out to gain access to the screw that holds the printer in place.
      Ask FixBot
    5. Texas Instruments TI-5130 Printer Unit  Replacement: step 5, image 1 of 2 Texas Instruments TI-5130 Printer Unit  Replacement: step 5, image 2 of 2
      • Using a PH1 screwdriver remove the 10mm screw that holds down the printer unit.
      • Remove the printer unit by lifting it up.
      Ask FixBot
3 other people completed this guide.
Author
with
Shannon Perkins
652 Reputation
3 Guides authored
2 Guide Comments
wehre did you buy the replacement printer
Tino ullrich - Reply Share
what sources are there for TI-5130 printer unit?
Norman Todd - Reply Share
Past 24 Hours: 8
Past 7 Days: 20
Past 30 Days: 100
All Time: 3,347
