Texas Instruments TI-5130 Power Cord Replacement
  1. Texas Instruments TI-5130 Power Cord Replacement, Power Cord: step 1, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement, Power Cord: step 1, image 2 of 2
    • Flip the calculator over and remove the 4 main 10mm screws with a PH1 screwdriver.
    Ask FixBot
  2. Texas Instruments TI-5130 Power Cord Replacement: step 2, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement: step 2, image 2 of 2
    • Remove the top cover.
    • Gently pull up on the power cord to remove it from the back cover.
    Ask FixBot
  3. Texas Instruments TI-5130 Power Cord Replacement: step 3, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement: step 3, image 2 of 2
    • This step is optional; however it makes it easier to work.
    • Using a PH1 screwdriver remove the two 10mm screws that hold down the transformer.
    • Gently remove the transformer.
    • Make sure that the calculator is not plugged in.
    Ask FixBot
  4. Texas Instruments TI-5130 Power Cord Replacement: step 4, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement: step 4, image 2 of 2
    • Use a wire cutter to cut off the white cap and expose the wires. Try to cut close to the tip of the white cap - to leave as much wire as possible.
    • Note that there are 2 sets of wires connected to the power cord. Do each set of wires separately.
    Ask FixBot
  5. Texas Instruments TI-5130 Power Cord Replacement: step 5, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement: step 5, image 2 of 2
    • Use a wire stripper to remove 1/2” of the protective covering on each of the wires.
    Ask FixBot
  6. Texas Instruments TI-5130 Power Cord Replacement: step 6, image 1 of 2 Texas Instruments TI-5130 Power Cord Replacement: step 6, image 2 of 2
    • Twist the exposed section of the 2 wires together.
    • Twist a new cap over the exposed wires. Make sure that the cap covers all of the exposed wire.
    • Repeat steps 4-6 for the second set of wires.
    Ask FixBot
  7. Texas Instruments TI-5130 Power Cord Replacement: step 7, image 1 of 1
    • Replace the transformer and ensure that the new wire caps fit in the space shown.
    • Plug in the new power cord and test the calculator before replacing the top cover.
    Ask FixBot
Shannon Perkins
652 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 851
